Datasheet Microchip PIC32MX530F128LT-50I/PF — Даташит
Производитель | Microchip |
Серия | PIC32MX530F128L |
Модель | PIC32MX530F128LT-50I/PF |
Datasheet PIC32MX1XX/2XX/5XX 64/100-PIN
PDF, 5.4 Мб, Язык: анг., Файл закачен: 30 дек 2020, Страниц: 390
32-bit Microcontrollers (up to 512 KB Flash and 64 KB SRAM) with Audio/Graphics/Touch (HMI), CAN, USB, and Advanced Analog
PIC32MX1XX/2XX/5XX 64/100-pin Family Data Sheet
PDF, 5.0 Мб, Версия: 10-13-2017
![]() 6 предложений от 6 поставщиков Микросхема Микроконтроллер 32, MCU 32Bit PIC32 PIC RISC 128KB Flash 2.5V/3.3V 100Pin TQFP T/R | |||
PIC32MX530F128LT-50I/PF Microchip | 155 ₽ | ||
PIC32MX530F128LT-50I/PF Microchip | 256 ₽ | ||
PIC32MX530F128LT-50I/PF Microchip | 478 ₽ | ||
PIC32MX530F128LT-50I/PF Microchip | по запросу |
Корпус | TQFP |
ADC Input | 48 |
Архитектура | 32 |
Auxiliary Flash | 3 KB |
Тактовая частота процессора | 83 MIPS/DMIPS |
CPU Type | 32-bit MIPS MCU |
CTMU test | No |
Crypto Engine | No |
Direct Memory Access Channels | 8 |
Graphics Controller/GPU | No |
Hardware Cap Voltage Divider | False |
Hardware RTCC/RTC | No |
I2C | 2 |
I2S | 4 |
Input Capture | 5 |
IrDA | Yes |
LIN | Yes |
Lead Count | 100 |
Low Power | No |
Max 16-Bit Digital Timers | 5 |
Max 32-Bit Digital Timers | 2 |
Max ADC Sampling Rate | 1000 ksps |
Max I/O Pins | 81 |
Max PWM outputs | 5 including complementary |
Number of ADCs | 1 |
Number of CAN Modules | 1 |
Количество компараторов | 3 |
Number of PWM Time Bases | 1 |
Number of USB Modules | 1 |
Operation Voltage Max | 3.6 В |
Operation Voltage Min | 2.3 В |
PWM Max Resolution | 16 Bits |
PWM Resolution | 25 нс |
Parallel Port | PMP |
Peripheral Trigger Generator | False |
Pincount | 100 |
Размер памяти программ | 128 KB |
RAM | 16 KB |
SPI | 4 |
Temp Range Max | 105 |
Temp Range Min | -40 |
UART | 5 |
Vbat/Vddbu battery backup | No |
Серия: PIC32MX530F128L (12)
- MCUs/MPUs with Connectivity > CAN
PIC32MX530F128LT50I/PF, PIC32MX530F128LT 50I/PF
