Datasheet Microchip PIC32MX530F128LT-I/PF — Даташит
СерияPIC32MX530F128L
МодельPIC32MX530F128LT-I/PF
Datasheet PIC32MX1XX/2XX/5XX 64/100-PIN
PDF, 5.4 Мб, Язык: анг., Файл закачен: 30 дек 2020, Страниц: 390
32-bit Microcontrollers (up to 512 KB Flash and 64 KB SRAM) with Audio/Graphics/Touch (HMI), CAN, USB, and Advanced Analog
PIC32MX1XX/2XX/5XX 64/100-pin Family Data Sheet
PDF, 5.0 Мб, Версия: 10-13-2017
IC MCU 32BIT 128KB FLASH 100TQFP. MIPS32® M4KTM PIC® 32MX Microcontroller IC 32-Bit 40MHz 128KB (128K x 8) FLASH 100-TQFP...
243 ₽
373 ₽
Hi-Tech Circuit Group
КорпусTQFP
ADC Input48
Архитектура32
Auxiliary Flash3 KB
Тактовая частота процессора83 MIPS/DMIPS
CPU Type32-bit MIPS MCU
CTMU testNo
Crypto EngineNo
Direct Memory Access Channels8
Graphics Controller/GPUNo
Hardware Cap Voltage DividerFalse
Hardware RTCC/RTCNo
I2C2
I2S4
Input Capture5
IrDAYes
LINYes
Lead Count100
Low PowerNo
Max 16-Bit Digital Timers5
Max 32-Bit Digital Timers2
Max ADC Resolution10 Bits
Max ADC Sampling Rate1000 ksps
Max I/O Pins81
Max PWM outputs5 including complementary
Number of ADCs1
Number of CAN Modules1
Количество компараторов3
Number of PWM Time Bases1
Number of USB Modules1
Operation Voltage Max3.6 В
Operation Voltage Min2.3 В
PWM Max Resolution16 Bits
PWM Resolution25 нс
Parallel PortPMP
Peripheral Trigger GeneratorFalse
Pincount100
Размер памяти программ128 KB
RAM16 KB
SPI4
Temp Range Max105
Temp Range Min-40
UART5
Vbat/Vddbu battery backupNo
PIC32MX530F128H
  • MCUs/MPUs with Connectivity > CAN
PIC32MX530F128LTI/PF, PIC32MX530F128LT I/PF
На английском языке: Datasheet Microchip PIC32MX530F128LT-I/PF
