Datasheet Microchip ATSAMC20G18A-MUT — Даташит
| Производитель | Microchip |
| Серия | ATSAMC20G18A |
| Модель | ATSAMC20G18A-MUT |
Серия устройств Microchip SAM C с напряжением 5 В Cortex M0+ предназначена для промышленного и коммерческого применения в шумных условиях.
Купить ATSAMC20G18A-MUT на РадиоЛоцман.Цены — от 95 до 688 ₽27 предложений от 15 поставщиков IC MCU 32BIT 256KB FLASH 48QFN. ARM® Cortex®-M0+ SAM C20 Microcontroller IC 32-Bit 48MHz 256KB (256K x 8) FLASH 48-QFN (7x7).... | |||
| ATSAMC20G18A-MUT | 213 ₽ | ||
| ATSAMC20G18A-MUT Microchip | 224 ₽ | ||
| ATSAMC20G18A-MUT Microchip | 335 ₽ | ||
| ATSAMC20G18A-MUT Microchip | от 654 ₽ | ||
| Корпус | VQFN |
| Количество выводов | 48 |
| # of Comparators | 2 |
| ADCC with Computation | No |
| Angular Timer | Yes |
| Архитектура | 32 |
| CPU | Cortex-M0+ |
| CRC/Scan | Yes |
| Configurable Logic Cell Modules | 4 CLC |
| Hardware Touch Peripheral | PTC |
| High Voltage Capable | No |
| I2C | 4 |
| Internal Oscillator | 32khz, 32Khz ULP, 48Mhz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 24 including complementary outputs |
| Max 16 Bit Digital Timers | 5 |
| Max 8 Bit Digital Timers | 5 |
| Max A/D Resolution | 12 bits |
| Max PWM Resolution | 32 bits |
| Max. CPU Speed MHz | 48 |
| Рабочий диапазон температур | от -40 до +85 °C |
| Operation Voltage Max.(V) | 5.5 |
| Operation Voltage Min.(V) | 2.7 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 48 |
| Размер памяти программ | 256 Kbytes |
| RAM | 32768 bytes |
| SPIв„ў | 4 |
| Signal Measurement Timer | 1 |
| Temp. Range Max. | 85 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 12 |
| UART | 4 |
| Windowed Watchdog Timer | No WWDT |
| Zero Cross detect | No |
ATSAMC20E15A ATSAMC20E16A ATSAMC20E17A ATSAMC20E18A ATSAMC20G15A ATSAMC20G16A ATSAMC20G17A ATSAMC20J15A ATSAMC20J16A ATSAMC20J17A ATSAMC20J18A ATSAMC20N17A ATSAMC20N18A ATSAMC21E17A ATSAMC21E18A ATSAMC21G17A ATSAMC21G18A ATSAMC21J17A ATSAMC21J18A ATSAMC21N17A ATSAMC21N18A
Серия: ATSAMC20G18A (4)
- ATSAMC20G18A-ANT ATSAMC20G18A-AUT ATSAMC20G18A-MNT ATSAMC20G18A-MUT
ATSAMC20G18AMUT, ATSAMC20G18A MUT
