Datasheet Microchip ATSAMDA1G14B-MBT — Даташит
Производитель | Microchip |
Серия | ATSAMDA1G14B |
Модель | ATSAMDA1G14B-MBT |
Микроконтроллеры SAM DA1 на базе ARM® Cortex®M0+ работают на частоте 48 МГц (45DMIPS).
![]() 16 предложений от 8 поставщиков , 48 QFN 5x5x0.9mm, TAPE & REEL, CM0, 16KB FLASH, 4KB SRAM, QFN48 48 VQFN 7x7x0.5mm T/R | |||
ATSAMDA1G14B-MBT Microchip | 230 ₽ | ||
ATSAMDA1G14B-MBT Microchip | 303 ₽ | ||
ATSAMDA1G14B-MBT Microchip | от 609 ₽ | ||
ATSAMDA1G14B-MBT Microchip | по запросу |
Корпус | VQFN |
Количество выводов | 48 |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M0+ |
CRC/Scan | Yes |
EEPROM / HEF | 1024 |
Hardware Touch Peripheral | PTC |
High Voltage Capable | No |
I2C | 6 |
Internal Oscillator | 32khz, 32Khz ULP, 8Mhz |
Math Accelerator | No |
Max # PWM outputs | 20 including complementary outputs |
Max 8 Bit Digital Timers | 5 |
Max D/A Resolution | 10 bits |
Max. CPU Speed MHz | 48 |
Number of USB Modules | 1 |
Рабочий диапазон температур | от -40 до +105 °C |
Operation Voltage Max.(V) | 3.63 |
Operation Voltage Min.(V) | 2.7 |
Pin count | 48 |
Размер памяти программ | 16 Kbytes |
RAM | 4096 bytes |
SPIв„ў | 6 |
Temp. Range Max. | 105 |
Temp. Range Min. | -40 |
Total # of A/D channels | 14 |
UART | 6 |
Zero Cross detect | No |
ATSAMDA1E14A ATSAMDA1E14B ATSAMDA1E15A ATSAMDA1E15B ATSAMDA1E16A ATSAMDA1E16B ATSAMDA1G14A ATSAMDA1G15A ATSAMDA1G15B ATSAMDA1G16A ATSAMDA1G16B ATSAMDA1J14A ATSAMDA1J14B ATSAMDA1J15A ATSAMDA1J15B ATSAMDA1J16A ATSAMDA1J16B
Серия: ATSAMDA1G14B (2)
- ATSAMDA1G14B-ABT ATSAMDA1G14B-MBT
ATSAMDA1G14BMBT, ATSAMDA1G14B MBT
