Datasheet Microchip ATSAMDA1J14B — Даташит
| Производитель | Microchip |
| Серия | ATSAMDA1J14B |
Микроконтроллеры SAM DA1 ARM® Cortex®-M0+ работают на частоте 48 МГц (45DMIPS).
Купить ATSAMDA1J14B на РадиоЛоцман.Цены — от 83 до 607 ₽20 предложений от 12 поставщиков IC MCU 32BIT 16KB FLASH 64TQFP. ARM® Cortex®-M0+ SAM DA1 Microcontroller IC 32-Bit 48MHz 16KB (16K x 8) FLASH 64-TQFP (10x10).... | |||
| ATSAMDA1J14B-ABT | 259 ₽ | ||
| ATSAMDA1J14B-ABT Microchip | 305 ₽ | ||
| ATSAMDA1J14B-ABT Microchip | от 547 ₽ | ||
| ATSAMDA1J14B-ABT Microchip | по запросу | ||
| ATSAMDA1J14B-ABT | |
| N | 1 |
| Корпус | TQFP |
| Количество выводов | 64 |
| Parameters / Models | ATSAMDA1J14B-ABT |
| # of Comparators | 2 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 32 |
| CPU | Cortex-M0+ |
| CRC/Scan | Yes |
| EEPROM / HEF | 2048 |
| Hardware Touch Peripheral | PTC |
| High Voltage Capable | No |
| I2C | 6 |
| Internal Oscillator | 32khz, 32Khz ULP, 8Mhz |
| Internal Voltage Reference, Bandgap | Yes |
| Math Accelerator | No |
| Max # PWM outputs, including complementary outputs | 24 |
| Max 16 Bit Digital Timers | 5 |
| Max 8 Bit Digital Timers | 5 |
| Max A/D Resolution, bits | 12 |
| Max D/A Resolution, bits | 10 |
| Max. CPU Speed MHz | 48 |
| Number of D/A Converters | 1 |
| Number of USB Modules | 1 |
| Рабочий диапазон температур, °C | от -40 до +105 |
| Operation Voltage Max.(V) | 3.63 |
| Operation Voltage Min.(V) | 2.7 |
| Peripheral Pin Select, PPS | Yes |
| Pin count | 64 |
| Размер памяти программ, Kbytes | 16 |
| RAM, bytes | 4096 |
| SPIв„ў | 6 |
| Temp. Range Max. | 105 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 20 |
| UART | 6 |
| Windowed Watchdog Timer, WWDT | No |
| Zero Cross detect | No |
ATSAMDA1E14A ATSAMDA1E14B ATSAMDA1E15A ATSAMDA1E15B ATSAMDA1E16A ATSAMDA1E16B ATSAMDA1G14A ATSAMDA1G14B ATSAMDA1G15A ATSAMDA1G15B ATSAMDA1G16A ATSAMDA1G16B ATSAMDA1J14A ATSAMDA1J15A ATSAMDA1J15B ATSAMDA1J16A ATSAMDA1J16B
Серия: ATSAMDA1J14B (1)
