Datasheet Microchip ATSAMDA1J15B — Даташит
Производитель | Microchip |
Серия | ATSAMDA1J15B |
Микроконтроллеры SAM DA1 ARM® Cortex®-M0+ работают на частоте 48 МГц (45DMIPS).
![]() 5 предложений от 5 поставщиков , 64 QFN 5x5x0.9mm, TAPE & REEL, CM0, 32KB FLASH, 4KB SRAM, QFN64 64 VQFN 9x9x0.5mm T/R | |||
ATSAMDA1J15B-MBT Microchip | 82 ₽ | ||
ATSAMDA1J15B-ABT Microchip | 255 ₽ | ||
ATSAMDA1J15B-ABT Microchip | по запросу | ||
ATSAMDA1J15B-ABT | |
N | 1 |
Корпус | TQFP |
Количество выводов | 64 |
Parameters / Models | ATSAMDA1J15B-ABT |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | Cortex-M0+ |
CRC/Scan | Yes |
EEPROM / HEF | 2048 |
Hardware Touch Peripheral | PTC |
High Voltage Capable | No |
I2C | 6 |
Internal Oscillator | 32khz, 32Khz ULP, 8Mhz |
Internal Voltage Reference, Bandgap | Yes |
Math Accelerator | No |
Max # PWM outputs, including complementary outputs | 24 |
Max 8 Bit Digital Timers | 5 |
Max A/D Resolution, bits | 12 |
Max D/A Resolution, bits | 10 |
Max. CPU Speed MHz | 48 |
Number of USB Modules | 1 |
Рабочий диапазон температур, °C | от -40 до +105 |
Operation Voltage Max.(V) | 3.63 |
Operation Voltage Min.(V) | 2.7 |
Peripheral Pin Select, PPS | Yes |
Pin count | 64 |
Размер памяти программ, Kbytes | 32 |
RAM, bytes | 4096 |
SPIв„ў | 6 |
Temp. Range Max. | 105 |
Temp. Range Min. | -40 |
Total # of A/D channels | 20 |
UART | 6 |
Windowed Watchdog Timer, WWDT | No |
Zero Cross detect | No |
ATSAMDA1E14A ATSAMDA1E14B ATSAMDA1E15A ATSAMDA1E15B ATSAMDA1E16A ATSAMDA1E16B ATSAMDA1G14A ATSAMDA1G14B ATSAMDA1G15A ATSAMDA1G15B ATSAMDA1G16A ATSAMDA1G16B ATSAMDA1J14A ATSAMDA1J14B ATSAMDA1J15A ATSAMDA1J16A ATSAMDA1J16B
Серия: ATSAMDA1J15B (1)
