Datasheet Microchip PIC16F1788T-I/SO — Даташит
СерияPIC16F1788
МодельPIC16F1788T-I/SO
Datasheet PIC16F1788, PIC16F1789
PDF, 6.2 Мб, Язык: анг., Файл закачен: 8 ноя 2017, Страниц: 474
28-Pin 8-Bit Advanced Analog Flash Microcontroller
Микросхема Микроконтроллер, 28KB Flash, 2KB RAM, 256B EEPROM, 12Bit ADC, 5Bit & 8Bit DAC, PSMC, OPAmp, FastComp, CCP, I2C/SPI, EUSART
PIC16F1788T-I/SO
110 ₽
PIC16F1788T-I/SO
158 ₽
PIC16F1788T-I/SO
PIC16F1788T-I/SO
КорпусSOIC
ADC Input11
ADC with ComputationNo
Angular TimerNo
Архитектура8
CPU Type8-bit PIC MCU
CRCNo
Class B SupportNo
Emulated EEPROM in Flash256
High Voltage CapableNo
I2C1
Lead Count28
Math AcceleratorNo
Max 16-Bit Digital Timers1
Max 8-Bit Digital Timers2
Max ADC Resolution12 Bits
Max CPU Speed32 МГц
Max DAC Resolution8 Bits
Max PWM outputs21 including complementary
Количество компараторов4
Number of DACs4
Number of Op Amps2
Operation Voltage Max5.5 В
Operation Voltage Min1.8 В
PWM Max Resolution16 Bits
Package Width.300in
Peripheral Pin Select / Pin MuxingNo
Pin count28
Размер памяти программ28 KB
Programmable Switched Mode Controller4
SPI1
SRAM2048 Bytes
Temp Range Max125
Temp Range Min-40
UART1
Zero Cross detectNo
PIC16F1789
  • 8-bit Microcontrollers > PIC16 MCU
PIC16F1788TI/SO, PIC16F1788T I/SO
На английском языке: Datasheet Microchip PIC16F1788T-I/SO
