Datasheet Microchip PIC16F1788T-E/MLVAO — Даташит
| Производитель | Microchip |
| Серия | PIC16F1788 |
| Модель | PIC16F1788T-E/MLVAO |
Datasheet PIC16F1788, PIC16F1789
PDF, 6.2 Мб, Язык: анг., Файл закачен: 8 ноя 2017, Страниц: 474
28-Pin 8-Bit Advanced Analog Flash Microcontroller
, 8Bit PIC Microcontrollers | |||
| PIC16F1788T-E/MLVAO Microchip | 129 ₽ | ||
| Корпус | QFN |
| ADC Input | 11 |
| ADC with Computation | No |
| Angular Timer | No |
| Архитектура | 8 |
| CPU Type | 8-bit PIC MCU |
| CRC | No |
| Class B Support | No |
| Emulated EEPROM in Flash | 256 |
| High Voltage Capable | No |
| I2C | 1 |
| Internal Oscillator | 32 MHz, 32 kHz |
| Internal Voltage Reference | Yes Bandgap |
| Lead Count | 28 |
| Math Accelerator | No |
| Max 16-Bit Digital Timers | 1 |
| Max 8-Bit Digital Timers | 2 |
| Max ADC Resolution | 12 Bits |
| Max CPU Speed | 32 МГц |
| Max DAC Resolution | 8 Bits |
| Max PWM outputs | 21 including complementary |
| Количество компараторов | 4 |
| Number of DACs | 4 |
| Number of Op Amps | 2 |
| Operation Voltage Max | 5.5 В |
| Operation Voltage Min | 1.8 В |
| PWM Max Resolution | 16 Bits |
| Package Width | 6x6x0.9mm |
| Peripheral Pin Select / Pin Muxing | No |
| Pin count | 28 |
| Размер памяти программ | 28 KB |
| Programmable Switched Mode Controller | 4 |
| SPI | 1 |
| SRAM | 2048 Bytes |
| Temp Range Max | 125 |
| Temp Range Min | -40 |
| UART | 1 |
| Zero Cross detect | No |
Серия: PIC16F1788 (28)
- PIC16F1788-E/ML PIC16F1788-E/MLVAO PIC16F1788-E/SO PIC16F1788-E/SP PIC16F1788-E/SS PIC16F1788-I/ML PIC16F1788-I/SO PIC16F1788-I/SP PIC16F1788-I/SS PIC16F1788T-E/ML PIC16F1788T-E/MLVAO PIC16F1788T-E/SS PIC16F1788T-E/SSVAO PIC16F1788T-I/ML PIC16F1788T-I/SO PIC16F1788T-I/SS PIC16F1788T-I/SSVAO PIC16LF1788-E/ML PIC16LF1788-E/SO PIC16LF1788-E/SP PIC16LF1788-E/SS PIC16LF1788-I/ML PIC16LF1788-I/SO PIC16LF1788-I/SP PIC16LF1788-I/SS PIC16LF1788T-I/ML PIC16LF1788T-I/SO PIC16LF1788T-I/SS
- 8-bit Microcontrollers > PIC16 MCU
PIC16F1788TE/MLVAO, PIC16F1788T E/MLVAO
Купить PIC16F1788T-E/MLVAO на РадиоЛоцман.Цены
