Datasheet Microchip PIC16F1789-I/PT — Даташит
| Производитель | Microchip |
| Серия | PIC16F1789 |
| Модель | PIC16F1789-I/PT |
Datasheet PIC16F1788, PIC16F1789
PDF, 6.2 Мб, Язык: анг., Файл закачен: 8 ноя 2017, Страниц: 474
28-Pin 8-Bit Advanced Analog Flash Microcontroller
Купить PIC16F1789-I/PT на РадиоЛоцман.Цены — от 67 до 3 209 ₽36 предложений от 21 поставщиков IC MCU 8BIT 28KB FLASH 44TQFP. PIC PIC® XLPTM 16F Microcontroller IC 8-Bit 32MHz 28KB (16K x 14) FLASH 44-TQFP... | |||
| PIC16F1789-I/PT Microchip | 171 ₽ | ||
| PIC16F1789-I/PT Microchip | 348 ₽ | ||
| PIC16F1789-I/PT Microchip | 369 ₽ | ||
| PIC16F1789-I/PT Microchip | по запросу | ||
| Корпус | TQFP |
| ADC Input | 15 |
| ADC with Computation | No |
| Angular Timer | No |
| Архитектура | 8 |
| CPU Type | 8-bit PIC MCU |
| CRC | No |
| Class B Support | No |
| Emulated EEPROM in Flash | 256 |
| High Voltage Capable | No |
| I2C | 1 |
| Internal Oscillator | 32 MHz, 32 kHz |
| Internal Voltage Reference | Yes Bandgap |
| Lead Count | 44 |
| Math Accelerator | No |
| Max 16-Bit Digital Timers | 1 |
| Max 8-Bit Digital Timers | 2 |
| Max ADC Resolution | 12 Bits |
| Max CPU Speed | 32 МГц |
| Max DAC Resolution | 8 Bits |
| Max PWM outputs | 21 including complementary |
| Количество компараторов | 4 |
| Number of DACs | 4 |
| Number of Op Amps | 3 |
| Operation Voltage Max | 5.5 В |
| Operation Voltage Min | 1.8 В |
| PWM Max Resolution | 16 Bits |
| Package Width | 10x10x1mm |
| Peripheral Pin Select / Pin Muxing | No |
| Pin count | 40 |
| Размер памяти программ | 28 KB |
| Programmable Switched Mode Controller | 4 |
| SPI | 1 |
| SRAM | 2048 Bytes |
| Temp Range Max | 125 |
| Temp Range Min | -40 |
| UART | 1 |
| Zero Cross detect | No |
Серия: PIC16F1789 (25)
- PIC16F1789-E/ML PIC16F1789-E/MV PIC16F1789-E/P PIC16F1789-E/PT PIC16F1789-I/ML PIC16F1789-I/MV PIC16F1789-I/P PIC16F1789-I/PT PIC16F1789-ME2/PF PIC16F1789T-E/MV PIC16F1789T-E/PT PIC16F1789T-I/ML PIC16F1789T-I/MV PIC16F1789T-I/PT PIC16LF1789-E/ML PIC16LF1789-E/MV PIC16LF1789-E/P PIC16LF1789-E/PT PIC16LF1789-I/ML PIC16LF1789-I/MV PIC16LF1789-I/P PIC16LF1789-I/PT PIC16LF1789T-I/ML PIC16LF1789T-I/MV PIC16LF1789T-I/PT
- 8-bit Microcontrollers > PIC16 MCU
PIC16F1789I/PT, PIC16F1789 I/PT
