Datasheet Microchip PIC16F1789T-I/MV — Даташит
| Производитель | Microchip |
| Серия | PIC16F1789 |
| Модель | PIC16F1789T-I/MV |
Datasheet PIC16F1788, PIC16F1789
PDF, 6.2 Мб, Язык: анг., Файл закачен: 8 ноя 2017, Страниц: 474
28-Pin 8-Bit Advanced Analog Flash Microcontroller
Купить PIC16F1789T-I/MV на РадиоЛоцман.Цены — от 65 до 173 ₽11 предложений от 11 поставщиков Микросхема Микроконтроллер, 28KB Flash, 2KB RAM, 256B EEPROM, 12Bit ADC, 5Bit & 8Bit DAC, PSMC, OPAmp, FastComp, CCP, I2C/SPI, EUSART | |||
| PIC16F1789T-I/MV Microchip | 164 ₽ | ||
| PIC16F1789T-I/MV Microchip | по запросу | ||
| Корпус | UQFN |
| ADC Input | 15 |
| ADC with Computation | No |
| Angular Timer | No |
| Архитектура | 8 |
| CPU Type | 8-bit PIC MCU |
| CRC | No |
| Class B Hardware | No |
| Emulated EEPROM in Flash | 256 |
| High Voltage Capable | No |
| I2C | 1 |
| Internal Oscillator | 32 MHz, 32 kHz |
| Internal Voltage Reference | Yes Bandgap |
| Lead Count | 40 |
| Math Accelerator | No |
| Max 16-Bit Digital Timers | 1 |
| Max 8-Bit Digital Timers | 2 |
| Max ADC Resolution | 12 Bits |
| Max CPU Speed | 32 МГц |
| Max DAC Resolution | 8 Bits |
| Max PWM outputs | 21 including complementary |
| Количество компараторов | 4 |
| Number of DACs | 4 |
| Number of Op Amps | 3 |
| Operation Voltage Max | 5.5 В |
| Operation Voltage Min | 1.8 В |
| PWM Max Resolution | 16 Bits |
| Package Width | 5x5x0.5mm |
| Peripheral Pin Select / Pin Muxing | No |
| Pin count | 40 |
| Размер памяти программ | 28 KB |
| Programmable Switched Mode Controller | 4 |
| SPI | 1 |
| SRAM | 2048 Bytes |
| Temp Range Max | 125 |
| Temp Range Min | -40 |
| UART | 1 |
| Zero Cross detect | No |
Серия: PIC16F1789 (25)
- PIC16F1789-E/ML PIC16F1789-E/MV PIC16F1789-E/P PIC16F1789-E/PT PIC16F1789-I/ML PIC16F1789-I/MV PIC16F1789-I/P PIC16F1789-I/PT PIC16F1789-ME2/PF PIC16F1789T-E/MV PIC16F1789T-E/PT PIC16F1789T-I/ML PIC16F1789T-I/MV PIC16F1789T-I/PT PIC16LF1789-E/ML PIC16LF1789-E/MV PIC16LF1789-E/P PIC16LF1789-E/PT PIC16LF1789-I/ML PIC16LF1789-I/MV PIC16LF1789-I/P PIC16LF1789-I/PT PIC16LF1789T-I/ML PIC16LF1789T-I/MV PIC16LF1789T-I/PT
- Microcontrollers > 8-bit Microcontrollers
PIC16F1789TI/MV, PIC16F1789T I/MV
