Datasheet Microchip PIC24FJ128GB410-I/PT — Даташит
СерияPIC24FJ128GB410
МодельPIC24FJ128GB410-I/PT
16-битный микроконтроллер PIC24F со встроенным аппаратным криптографическим модулем и чрезвычайно низким энергопотреблением
PIC24FJ256GA412/PIC24FJ256GB412 Data Sheet
PDF, 4.2 Мб, Версия: 12-01-2016
IC MCU 16BIT 128KB FLASH 100TQFP. PIC PIC® XLPTM 24F Microcontroller IC 16-Bit 32MHz 128KB (43K x 24) FLASH 100-TQFP...
286 ₽
413 ₽
Hi-Tech Circuit Group
КорпусTQFP
Количество выводов100
# of Comparators3
ADCC with ComputationNo
Angular TimerNo
Архитектура16
CPU16-bit PIC MCU
CRC/ScanYes
Configurable Logic Cell Modules4 CLC
EEPROM / HEF0 / HEF
High Voltage CapableNo
I2C3
Internal Oscillator8 MHz, 31 kHz
Math AcceleratorNo
Max # PWM outputs6 including complementary outputs
Max 16 Bit Digital Timers31
Max A/D Resolution12 bits
Max D/A Resolution10 bits
Max PWM Resolution16 bits
Max. CPU Speed MHz32
Number of D/A Converters1
Number of USB Modules1
Operation Voltage Max.(V)3.6
Operation Voltage Min.(V)2
Peripheral Pin SelectYes PPS
Pin count100
Размер памяти программ128 Kbytes
RAM16384 bytes
SPIв„ў4
Segment LCD480
Temp. Range Max.85
Temp. Range Min.-40
Total # of A/D channels24
UART6
Zero Cross detectNo
PIC24FJ128GA406 PIC24FJ128GA410 PIC24FJ128GA412 PIC24FJ128GB406 PIC24FJ128GB412 PIC24FJ256GA406 PIC24FJ256GA410 PIC24FJ256GA412 PIC24FJ256GB406 PIC24FJ256GB410 PIC24FJ256GB412 PIC24FJ64GA406 PIC24FJ64GA410 PIC24FJ64GA412 PIC24FJ64GB406 PIC24FJ64GB410 PIC24FJ64GB412
Серия: PIC24FJ128GB410 (2)
PIC24FJ128GB410I/PT, PIC24FJ128GB410 I/PT
На английском языке: Datasheet Microchip PIC24FJ128GB410-I/PT
