Datasheet Microchip DSPIC33EP256MC202-E/SS — Даташит
Производитель | Microchip |
Серия | dsPIC33EP256MC202 |
Модель | DSPIC33EP256MC202-E/SS |
MicrochipвЂs dsPIC33E family of digital signal controllers (DSCs) features a 70 MIPS dsPICВ® DSC core with integrated DSP and enhanced on-chip peripherals
16-Bit Microcontrollers and Digital Signal Controllers with High-Speed PWM, Op Amps and Advanced Analog
![]() 11 предложений от 11 поставщиков Микросхема Микроконтроллер, SSOP 16Bit DSC, 256KB Flash, 32KB RAM, 60MHz, 28Pin, MCPWM, QEI, OpAmps, Comparators, PTG | |||
DSPIC33EP256MC202-E/SS Microchip | по запросу | ||
Корпус | SSOP |
Количество выводов | 28 |
# of Comparators | 3 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | Yes |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 7.37 MHz, 32 kHz |
Math Accelerator | No |
Max # PWM outputs | 10 including complementary outputs |
Max D/A Resolution | 4 bits |
Max. CPU Speed MHz | 70 |
Рабочий диапазон температур | от -40 до +125 °C |
Operation Voltage Min.(V) | 3 |
Operational Amplifier | 2 |
Pin count | 28 |
Размер памяти программ | 256 Kbytes |
RAM | 32768 bytes |
SPIв„ў | 2 |
Temp. Range Max. | 125 |
Temp. Range Min. | -40 |
Total # of A/D channels | 6 |
UART | 2 |
Zero Cross detect | No |
dsPIC33EP128GP502 dsPIC33EP128GP504 dsPIC33EP128GP506 dsPIC33EP128MC202 dsPIC33EP128MC204 dsPIC33EP128MC206 dsPIC33EP128MC502 dsPIC33EP128MC504 dsPIC33EP128MC506 dsPIC33EP256GP502 dsPIC33EP256GP504 dsPIC33EP256GP506 dsPIC33EP256MC204 dsPIC33EP256MC206 dsPIC33EP256MC502 dsPIC33EP256MC504 dsPIC33EP256MC506 dsPIC33EP32GP502 dsPIC33EP32GP503 dsPIC33EP32GP504 dsPIC33EP32MC202 dsPIC33EP32MC203 dsPIC33EP32MC204 dsPIC33EP32MC502 dsPIC33EP32MC503 dsPIC33EP32MC504 dsPIC33EP512GP502 dsPIC33EP512GP504 dsPIC33EP512GP506 dsPIC33EP512MC202 dsPIC33EP512MC204 dsPIC33EP512MC206 dsPIC33EP512MC502 dsPIC33EP512MC504 dsPIC33EP512MC506 dsPIC33EP64GP502 dsPIC33EP64GP503 dsPIC33EP64GP504 dsPIC33EP64GP506 dsPIC33EP64MC202 dsPIC33EP64MC203 dsPIC33EP64MC204 dsPIC33EP64MC206 dsPIC33EP64MC502 dsPIC33EP64MC503 dsPIC33EP64MC504 dsPIC33EP64MC506
- DSPIC33EP256MC202-E/MM DSPIC33EP256MC202-E/SO DSPIC33EP256MC202-E/SP DSPIC33EP256MC202-E/SS DSPIC33EP256MC202-H/MM DSPIC33EP256MC202-H/SO DSPIC33EP256MC202-H/SP DSPIC33EP256MC202-H/SS DSPIC33EP256MC202-I/MM DSPIC33EP256MC202-I/SO DSPIC33EP256MC202-I/SP DSPIC33EP256MC202-I/SS DSPIC33EP256MC202T-E/MM DSPIC33EP256MC202T-E/SO DSPIC33EP256MC202T-E/SS DSPIC33EP256MC202T-H/MM DSPIC33EP256MC202T-H/SO DSPIC33EP256MC202T-H/SS DSPIC33EP256MC202T-I/MM DSPIC33EP256MC202T-I/SO DSPIC33EP256MC202T-I/SS
DSPIC33EP256MC202E/SS, DSPIC33EP256MC202 E/SS
