Datasheet Microchip DSPIC33EP256MU814T-E/PH — Даташит
СерияdsPIC33EP256MU814
МодельDSPIC33EP256MU814T-E/PH
MicrochipвЂs dsPIC33E motor control family of digital signal controllers (DSCs) features a 70 MIPS dsPICВ® DSC core with integrated DSP and enhanced on-chip peripherals
dsPIC33EPXXX(GP/MC/MU)806/810/814 and PIC24EPXXX(GP/GU)810/814 Data Sheet
PDF, 5.2 Мб, Версия: 10-17-2012
, 16Bit DSC 144LD 256KB Flash DMA 60MIPS nanoWatt
467 ₽
КорпусTQFP
Количество выводов144
# of Comparators3
ADCC with ComputationNo
Angular TimerNo
Архитектура16
CPU16-bit dsPIC DSC
CRC/ScanYes
EEPROM / HEF0 / HEF
High Voltage CapableNo
I2C2
Math AcceleratorNo
Max # PWM outputs30 including complementary outputs
Max 16 Bit Digital Timers9
Max A/D Resolution12 bits
Max D/A Resolution4 bits
Max PWM Resolution16 bits
Max. CPU Speed MHz60
Number of D/A Converters1
Number of USB Modules1
Operation Voltage Max.(V)3.6
Operation Voltage Min.(V)3
Peripheral Pin SelectYes PPS
Pin count144
Размер памяти программ256 Kbytes
RAM28672 bytes
SPIв„ў4
Temp. Range Max.125
Temp. Range Min.-40
Total # of A/D channels32
UART4
Zero Cross detectNo
dsPIC33EP256MU806 dsPIC33EP256MU810 dsPIC33EP512GP806 dsPIC33EP512MC806 dsPIC33EP512MU810 dsPIC33EP512MU814
DSPIC33EP256MU814TE/PH, DSPIC33EP256MU814T E/PH
На английском языке: Datasheet Microchip DSPIC33EP256MU814T-E/PH
