Datasheet Microchip DSPIC33EP32GP502-E/SP — Даташит
| Производитель | Microchip |
| Серия | dsPIC33EP32GP502 |
| Модель | DSPIC33EP32GP502-E/SP |
MicrochipвЂs dsPIC33E general purpose DSC family features the highest speed 70 MIPS core with excellent performance and code density
16-Bit Microcontrollers and Digital Signal Controllers with High-Speed PWM, Op Amps and Advanced Analog
Купить DSPIC33EP32GP502-E/SP на РадиоЛоцман.Цены — от 68 до 520 ₽12 предложений от 12 поставщиков IC MCU 16BIT 32KB FLASH 28SDIP. dsPIC Automotive, AEC-Q100, dsPICTM 33EP Microcontroller IC 16-Bit 60 MIPs 32KB (10.7K x 24)... | |||
| DSPIC33EP32GP502-E/SP Microchip | 182 ₽ | ||
| DSPIC33EP32GP502-E/SP Microchip | 196 ₽ | ||
| DSPIC33EP32GP502-E/SP Microchip | 520 ₽ | ||
| DSPIC33EP32GP502-E/SP Microchip | по запросу | ||
| Корпус | SPDIP |
| Количество выводов | 28 |
| # of Comparators | 3 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 16 |
| CPU | 16-bit dsPIC DSC |
| CRC/Scan | Yes |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| I2C | 2 |
| Internal Oscillator | 7.37 MHz, 32 kHz |
| Internal Voltage Reference | No Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 4 including complementary outputs |
| Max 16 Bit Digital Timers | 5 |
| Max A/D Resolution | 12 bits |
| Max D/A Resolution | 4 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 70 |
| Number of D/A Converters | 1 |
| Рабочий диапазон температур | от -40 до +125 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 3 |
| Operational Amplifier | 2 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 28 |
| Размер памяти программ | 32 Kbytes |
| RAM | 4096 bytes |
| SPIв„ў | 2 |
| Temp. Range Max. | 125 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 6 |
| UART | 2 |
| Windowed Watchdog Timer | Yes WWDT |
| Zero Cross detect | No |
dsPIC33EP128GP502 dsPIC33EP128GP504 dsPIC33EP128GP506 dsPIC33EP128MC202 dsPIC33EP128MC204 dsPIC33EP128MC206 dsPIC33EP128MC502 dsPIC33EP128MC504 dsPIC33EP128MC506 dsPIC33EP256GP502 dsPIC33EP256GP504 dsPIC33EP256GP506 dsPIC33EP256MC202 dsPIC33EP256MC204 dsPIC33EP256MC206 dsPIC33EP256MC502 dsPIC33EP256MC504 dsPIC33EP256MC506 dsPIC33EP32GP503 dsPIC33EP32GP504 dsPIC33EP32MC202 dsPIC33EP32MC203 dsPIC33EP32MC204 dsPIC33EP32MC502 dsPIC33EP32MC503 dsPIC33EP32MC504 dsPIC33EP512GP502 dsPIC33EP512GP504 dsPIC33EP512GP506 dsPIC33EP512MC202 dsPIC33EP512MC204 dsPIC33EP512MC206 dsPIC33EP512MC502 dsPIC33EP512MC504 dsPIC33EP512MC506 dsPIC33EP64GP502 dsPIC33EP64GP503 dsPIC33EP64GP504 dsPIC33EP64GP506 dsPIC33EP64MC202 dsPIC33EP64MC203 dsPIC33EP64MC204 dsPIC33EP64MC206 dsPIC33EP64MC502 dsPIC33EP64MC503 dsPIC33EP64MC504 dsPIC33EP64MC506
- DSPIC33EP32GP502-E/MM DSPIC33EP32GP502-E/MMVAO DSPIC33EP32GP502-E/SO DSPIC33EP32GP502-E/SP DSPIC33EP32GP502-E/SS DSPIC33EP32GP502-E/SSVAO DSPIC33EP32GP502-H/MM DSPIC33EP32GP502-H/SO DSPIC33EP32GP502-H/SP DSPIC33EP32GP502-H/SS DSPIC33EP32GP502-I/MM DSPIC33EP32GP502-I/SO DSPIC33EP32GP502-I/SP DSPIC33EP32GP502-I/SS DSPIC33EP32GP502-I/SSVAO DSPIC33EP32GP502T-E/MM DSPIC33EP32GP502T-E/MMVAO DSPIC33EP32GP502T-E/SO DSPIC33EP32GP502T-E/SS DSPIC33EP32GP502T-E/SSVAO DSPIC33EP32GP502T-H/MM DSPIC33EP32GP502T-H/SO DSPIC33EP32GP502T-H/SS DSPIC33EP32GP502T-I/MM DSPIC33EP32GP502T-I/SO DSPIC33EP32GP502T-I/SS DSPIC33EP32GP502T-I/SSVAO
DSPIC33EP32GP502E/SP, DSPIC33EP32GP502 E/SP
