Datasheet Microchip DSPIC33EP512MU810T-E/BG — Даташит
| Производитель | Microchip |
| Серия | dsPIC33EP512MU810 |
| Модель | DSPIC33EP512MU810T-E/BG |
MicrochipвЂs dsPIC33E family of digital signal controllers (DSCs) features a 70 MIPS dsPICВ® DSC core with integrated DSP and enhanced on-chip peripherals
dsPIC33EPXXX(GP/MC/MU)806/810/814 and PIC24EPXXX(GP/GU)810/814 Data Sheet
PDF, 5.2 Мб, Версия: 10-17-2012
 Купить DSPIC33EP512MU810T-E/BG на РадиоЛоцман.Цены — от 652 до 733 ₽Микросхема Микроконтроллер, dsPIC33EP Series 52KB RAM 536KB Flash 16Bit Digital Signal Controller-TFBGA-100  | |||
| DSPIC33EP512MU810T-E/BG Microchip  | 652 ₽ | ||
| DSPIC33EP512MU810T-E/BG Microchip  | 733 ₽ | ||
| Корпус | TFBGA |
| Количество выводов | 121 |
| # of Comparators | 3 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 16 |
| CPU | 16-bit dsPIC DSC |
| CRC/Scan | Yes |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| I2C | 2 |
| Internal Oscillator | 7.37 MHz, 32 kHz |
| Internal Voltage Reference | No Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 28 including complementary outputs |
| Max 16 Bit Digital Timers | 9 |
| Max A/D Resolution | 12 bits |
| Max D/A Resolution | 4 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 60 |
| Number of D/A Converters | 1 |
| Number of USB Modules | 1 |
| Рабочий диапазон температур | от -40 до +125 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 3 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 100 |
| Размер памяти программ | 512 Kbytes |
| RAM | 53248 bytes |
| SPIв„ў | 4 |
| Temp. Range Max. | 125 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 32 |
| UART | 4 |
| Windowed Watchdog Timer | Yes WWDT |
| Zero Cross detect | No |
dsPIC33EP256MU806 dsPIC33EP256MU810 dsPIC33EP256MU814 dsPIC33EP512GP806 dsPIC33EP512MC806 dsPIC33EP512MU814
Серия: dsPIC33EP512MU810 (12)
DSPIC33EP512MU810TE/BG, DSPIC33EP512MU810T E/BG
