Datasheet Microchip DSPIC33EP64MC504T-H/TL — Даташит
СерияdsPIC33EP64MC504
МодельDSPIC33EP64MC504T-H/TL
MicrochipвЂs dsPIC33E family of digital signal controllers (DSCs) features a 70 MIPS dsPICВ® DSC core with integrated DSP and enhanced on-chip peripherals
Datasheet dsPIC33EPXXXGP50X, dsPIC33EPXXXMC20X/50X, PIC24EPXXXGP/MC20X
PDF, 9.4 Мб, Версия: 08-19-2013, Файл закачен: 9 ноя 2017, Страниц: 530
16-Bit Microcontrollers and Digital Signal Controllers with High-Speed PWM, Op Amps and Advanced Analog
, 16Bit DSC 64KB Flash 8KB RAM 60MHz 44Pin 3 OpAmp 4 Comp PTG CTMU CAN
DSPIC33EP64MC504T-H/MV
200 ₽
КорпусVTLA
Количество выводов44
# of Comparators4
ADCC with ComputationNo
Angular TimerNo
Архитектура16
CPU16-bit dsPIC DSC
CRC/ScanYes
EEPROM / HEF0 / HEF
High Voltage CapableNo
I2C2
Math AcceleratorNo
Max # PWM outputs10 including complementary outputs
Max 16 Bit Digital Timers5
Max A/D Resolution12 bits
Max D/A Resolution4 bits
Max PWM Resolution16 bits
Max. CPU Speed MHz70
Number of D/A Converters1
Operation Voltage Max.(V)3.6
Operation Voltage Min.(V)3
Operational Amplifier3
Peripheral Pin SelectYes PPS
Pin count44
Размер памяти программ64 Kbytes
RAM8192 bytes
SPIв„ў2
Temp. Range Max.125
Temp. Range Min.-40
Total # of A/D channels9
UART2
Zero Cross detectNo
dsPIC33EP128GP502 dsPIC33EP128GP504 dsPIC33EP128GP506 dsPIC33EP128MC202 dsPIC33EP128MC204 dsPIC33EP128MC206 dsPIC33EP128MC502 dsPIC33EP128MC504 dsPIC33EP128MC506 dsPIC33EP256GP502 dsPIC33EP256GP504 dsPIC33EP256GP506 dsPIC33EP256MC202 dsPIC33EP256MC204 dsPIC33EP256MC206 dsPIC33EP256MC502 dsPIC33EP256MC504 dsPIC33EP256MC506 dsPIC33EP32GP502 dsPIC33EP32GP503 dsPIC33EP32GP504 dsPIC33EP32MC202 dsPIC33EP32MC203 dsPIC33EP32MC204 dsPIC33EP32MC502 dsPIC33EP32MC503 dsPIC33EP32MC504 dsPIC33EP512GP502 dsPIC33EP512GP504 dsPIC33EP512GP506 dsPIC33EP512MC202 dsPIC33EP512MC204 dsPIC33EP512MC206 dsPIC33EP512MC502 dsPIC33EP512MC504 dsPIC33EP512MC506 dsPIC33EP64GP502 dsPIC33EP64GP503 dsPIC33EP64GP504 dsPIC33EP64GP506 dsPIC33EP64MC202 dsPIC33EP64MC203 dsPIC33EP64MC204 dsPIC33EP64MC206 dsPIC33EP64MC502 dsPIC33EP64MC503 dsPIC33EP64MC506
DSPIC33EP64MC504TH/TL, DSPIC33EP64MC504T H/TL
На английском языке: Datasheet Microchip DSPIC33EP64MC504T-H/TL
