Datasheet Microchip DSPIC33EV32GM102-I/SSVAO — Даташит
| Производитель | Microchip |
| Серия | dsPIC33EV32GM102 |
| Модель | DSPIC33EV32GM102-I/SSVAO |
Семейство контроллеров цифровых сигналов (DSC) dsPIC33EV от Microchip оснащено ядром dsPIC® DSC 5 В, 70 MIPS с расширенными встроенными функциями и идеально подходит для работы в суровых условиях, таких как бытовая техника и автомобильные приложения.
| DSPIC33EV32GM102-I/SSVAO Microchip | по запросу | ||
| Корпус | SSOP |
| Количество выводов | 28 |
| # of Comparators | 4 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 16 |
| CPU | 16-bit dsPIC DSC |
| CRC/Scan | No |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| I2C | 1 |
| Internal Oscillator | 7.37 MHz, 32 kHz |
| Internal Voltage Reference | No Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 10 including complementary outputs |
| Max 16 Bit Digital Timers | 5 |
| Max A/D Resolution | 12 bits |
| Max D/A Resolution | 7 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 70 |
| Number of D/A Converters | 1 |
| Operation Voltage Max.(V) | 5.5 |
| Operation Voltage Min.(V) | 4.5 |
| Operational Amplifier | 3 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 28 |
| Размер памяти программ | 32 Kbytes |
| RAM | 4096 bytes |
| SPIв„ў | 2 |
| Temp. Range Max. | 150 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 11 |
| UART | 2 |
| Windowed Watchdog Timer | Yes WWDT |
| Zero Cross detect | No |
dsPIC33EV128GM002 dsPIC33EV128GM004 dsPIC33EV128GM006 dsPIC33EV128GM102 dsPIC33EV128GM104 dsPIC33EV128GM106 dsPIC33EV256GM002 dsPIC33EV256GM004 dsPIC33EV256GM006 dsPIC33EV256GM102 dsPIC33EV256GM104 dsPIC33EV256GM106 dsPIC33EV32GM002 dsPIC33EV32GM004 dsPIC33EV32GM006 dsPIC33EV32GM104 dsPIC33EV32GM106 dsPIC33EV64GM002 dsPIC33EV64GM004 dsPIC33EV64GM006 dsPIC33EV64GM102 dsPIC33EV64GM104 dsPIC33EV64GM106
- DSPIC33EV32GM102-E/MM DSPIC33EV32GM102-E/SO DSPIC33EV32GM102-E/SP DSPIC33EV32GM102-E/SS DSPIC33EV32GM102-H/MM DSPIC33EV32GM102-H/SO DSPIC33EV32GM102-H/SP DSPIC33EV32GM102-H/SS DSPIC33EV32GM102-I/MM DSPIC33EV32GM102-I/SO DSPIC33EV32GM102-I/SP DSPIC33EV32GM102-I/SS DSPIC33EV32GM102-I/SSVAO DSPIC33EV32GM102T-E/SSVAO DSPIC33EV32GM102T-I/MM DSPIC33EV32GM102T-I/SO DSPIC33EV32GM102T-I/SSVAO
DSPIC33EV32GM102I/SSVAO, DSPIC33EV32GM102 I/SSVAO
