Datasheet Microchip DSPIC33FJ128GP804T-H/PT — Даташит
Производитель | Microchip |
Серия | dsPIC33FJ128GP804 |
Модель | DSPIC33FJ128GP804T-H/PT |
dsPIC33FJ32GP302/304, dsPIC33FJ64GPX02/X04 and dsPIC33FJ128GPX02/X04 Data Sheet
PDF, 6.3 Мб, Версия: 04-19-2012
16-bit MCU/DSC, 128 KB, 16384 Bytes, 40 MHz, 3 to 3.6V, TQFP-44, RoHS | |||
DSPIC33FJ128GP804T-H/PT Microchip | 380 ₽ | ||
DSPIC33FJ128GP804T-H/PT Microchip | по запросу |
Корпус | TQFP |
Количество выводов | 44 |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | Yes |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 7.37 MHz, 32.768 kHz |
Math Accelerator | No |
Max # PWM outputs | 4 including complementary outputs |
Max D/A Resolution | 16 bits |
Max. CPU Speed MHz | 40 |
Number of D/A Converters | 2 |
Рабочий диапазон температур | от -40 до +150 °C |
Operation Voltage Min.(V) | 3 |
Pin count | 44 |
Размер памяти программ | 128 Kbytes |
RAM | 16384 bytes |
SPIв„ў | 2 |
Temp. Range Max. | 150 |
Temp. Range Min. | -40 |
Total # of A/D channels | 13 |
UART | 2 |
Zero Cross detect | No |
dsPIC33FJ128GP202 dsPIC33FJ128GP204 dsPIC33FJ128GP802 dsPIC33FJ32GP302 dsPIC33FJ32GP304 dsPIC33FJ64GP202 dsPIC33FJ64GP204 dsPIC33FJ64GP802 dsPIC33FJ64GP804
Серия: dsPIC33FJ128GP804 (16)
- DSPIC33FJ128GP804-E/ML DSPIC33FJ128GP804-E/PT DSPIC33FJ128GP804-E/PTVAO DSPIC33FJ128GP804-H/ML DSPIC33FJ128GP804-H/PT DSPIC33FJ128GP804-I/ML DSPIC33FJ128GP804-I/PT DSPIC33FJ128GP804-I/PTVAO DSPIC33FJ128GP804T-E/ML DSPIC33FJ128GP804T-E/PT DSPIC33FJ128GP804T-E/PTVAO DSPIC33FJ128GP804T-H/ML DSPIC33FJ128GP804T-H/PT DSPIC33FJ128GP804T-I/ML DSPIC33FJ128GP804T-I/PT DSPIC33FJ128GP804T-I/PTVAO
DSPIC33FJ128GP804TH/PT, DSPIC33FJ128GP804T H/PT
