Datasheet Microchip DSPIC33FJ128MC202T-I/SO — Даташит
| Производитель | Microchip |
| Серия | dsPIC33FJ128MC202 |
| Модель | DSPIC33FJ128MC202T-I/SO |
dsPIC33FJ32MC302/304, dsPIC33FJ64MCX02/X04 and dsPIC33FJ128MCX02/X04 Data Sheet
PDF, 6.6 Мб, Версия: 04-19-2012
 Купить DSPIC33FJ128MC202T-I/SO на РадиоЛоцман.Цены — от 267 до 980 ₽11 предложений от 11 поставщиков IC MCU 16BIT 128KB FLASH 28SOIC. dsPIC dsPICTM 33F Microcontroller IC 16-Bit 40 MIPs 128KB (128K x 8) FLASH 28-SOIC....  | |||
| DSPIC33FJ128MC202T-I/SO Microchip  | 267 ₽ | ||
| DSPIC33FJ128MC202T-I/SO Microchip  | 368 ₽ | ||
| DSPIC33FJ128MC202T-I/SO Microchip  | 485 ₽ | ||
| DSPIC33FJ128MC202T-I/SO Microchip  | по запросу | ||
| Корпус | SOIC |
| Количество выводов | 28 |
| # of Comparators | 2 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 16 |
| CPU | 16-bit dsPIC DSC |
| CRC/Scan | Yes |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| I2C | 1 |
| Internal Oscillator | 7.37 MHz, 32.768 kHz |
| Internal Voltage Reference | No Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 12 including complementary outputs |
| Max 16 Bit Digital Timers | 5 |
| Max A/D Resolution | 12 bits |
| Max D/A Resolution | 4 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 40 |
| Number of D/A Converters | 1 |
| Рабочий диапазон температур | от -40 до +85 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 3 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 28 |
| Размер памяти программ | 128 Kbytes |
| RAM | 8192 bytes |
| SPIв„ў | 2 |
| Temp. Range Max. | 125 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 6 |
| UART | 2 |
| Windowed Watchdog Timer | Yes WWDT |
| Zero Cross detect | No |
dsPIC33FJ128MC204 dsPIC33FJ128MC802 dsPIC33FJ128MC804 dsPIC33FJ32MC302 dsPIC33FJ32MC304 dsPIC33FJ64MC202 dsPIC33FJ64MC204 dsPIC33FJ64MC802 dsPIC33FJ64MC804
Серия: dsPIC33FJ128MC202 (10)
DSPIC33FJ128MC202TI/SO, DSPIC33FJ128MC202T I/SO
