Datasheet Microchip DSPIC33FJ128MC204T-E/ML — Даташит
Производитель | Microchip |
Серия | dsPIC33FJ128MC204 |
Модель | DSPIC33FJ128MC204T-E/ML |
dsPIC33FJ32MC302/304, dsPIC33FJ64MCX02/X04 and dsPIC33FJ128MCX02/X04 Data Sheet
PDF, 6.6 Мб, Версия: 04-19-2012
, 16Bit MCU/DSP 44LD 40MIPS 128KB FLASH | |||
DSPIC33FJ128MC204T-E/ML Microchip | 343 ₽ | ||
DSPIC33FJ128MC204T-E/ML Microchip | по запросу |
Корпус | QFN |
Количество выводов | 44 |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | Yes |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 7.37 MHz, 32.768 kHz |
Math Accelerator | No |
Max # PWM outputs | 12 including complementary outputs |
Max D/A Resolution | 4 bits |
Max. CPU Speed MHz | 40 |
Рабочий диапазон температур | от -40 до +125 °C |
Operation Voltage Min.(V) | 3 |
Pin count | 44 |
Размер памяти программ | 128 Kbytes |
RAM | 8192 bytes |
SPIв„ў | 2 |
Temp. Range Max. | 125 |
Temp. Range Min. | -40 |
Total # of A/D channels | 9 |
UART | 2 |
Zero Cross detect | No |
dsPIC33FJ128MC202 dsPIC33FJ128MC802 dsPIC33FJ128MC804 dsPIC33FJ32MC302 dsPIC33FJ32MC304 dsPIC33FJ64MC202 dsPIC33FJ64MC204 dsPIC33FJ64MC802 dsPIC33FJ64MC804
Серия: dsPIC33FJ128MC204 (8)
DSPIC33FJ128MC204TE/ML, DSPIC33FJ128MC204T E/ML
