Datasheet Microchip DSPIC33FJ128MC804T-E/PT — Даташит
| Производитель | Microchip |
| Серия | dsPIC33FJ128MC804 |
| Модель | DSPIC33FJ128MC804T-E/PT |
dsPIC33FJ32MC302/304, dsPIC33FJ64MCX02/X04 and dsPIC33FJ128MCX02/X04 Data Sheet
PDF, 6.6 Мб, Версия: 04-19-2012
, 16Bit Mcu/Dsp 44ld 40MIPS 128KB Flash  | |||
| DSPIC33FJ128MC804T-E/PT Microchip  | 364 ₽ | ||
| DSPIC33FJ128MC804T-E/PT Microchip  | по запросу | ||
| Корпус | TQFP |
| Количество выводов | 44 |
| # of Comparators | 2 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 16 |
| CPU | 16-bit dsPIC DSC |
| CRC/Scan | Yes |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| I2C | 1 |
| Internal Oscillator | 7.37 MHz, 32.768 kHz |
| Internal Voltage Reference | No Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 12 including complementary outputs |
| Max 16 Bit Digital Timers | 5 |
| Max A/D Resolution | 12 bits |
| Max D/A Resolution | 16 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 40 |
| Number of D/A Converters | 2 |
| Рабочий диапазон температур | от -40 до +125 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 3 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 44 |
| Размер памяти программ | 128 Kbytes |
| RAM | 16384 bytes |
| SPIв„ў | 2 |
| Temp. Range Max. | 150 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 9 |
| UART | 2 |
| Windowed Watchdog Timer | Yes WWDT |
| Zero Cross detect | No |
dsPIC33FJ128MC202 dsPIC33FJ128MC204 dsPIC33FJ128MC802 dsPIC33FJ32MC302 dsPIC33FJ32MC304 dsPIC33FJ64MC202 dsPIC33FJ64MC204 dsPIC33FJ64MC802 dsPIC33FJ64MC804
Серия: dsPIC33FJ128MC804 (15)
- DSPIC33FJ128MC804-E/ML DSPIC33FJ128MC804-E/PT DSPIC33FJ128MC804-E/PTVAO DSPIC33FJ128MC804-H/ML DSPIC33FJ128MC804-H/MLVAO DSPIC33FJ128MC804-H/PT DSPIC33FJ128MC804-I/ML DSPIC33FJ128MC804-I/PT DSPIC33FJ128MC804T-E/ML DSPIC33FJ128MC804T-E/PT DSPIC33FJ128MC804T-H/ML DSPIC33FJ128MC804T-H/MLVAO DSPIC33FJ128MC804T-H/PT DSPIC33FJ128MC804T-I/ML DSPIC33FJ128MC804T-I/PT
DSPIC33FJ128MC804TE/PT, DSPIC33FJ128MC804T E/PT
Купить DSPIC33FJ128MC804T-E/PT на РадиоЛоцман.Цены
