Datasheet Microchip DSPIC33FJ16GS402-E/SP — Даташит
| Производитель | Microchip |
| Серия | dsPIC33FJ16GS402 |
| Модель | DSPIC33FJ16GS402-E/SP |
dsPIC33FJXXGSXXX SMPS и цифровой преобразователь энергии 16-битный контроллер цифровых сигналов
dsPIC33FJ06GS101/X02 and dsPIC33FJ16GSX02/X04 Data Sheet
PDF, 3.7 Мб, Версия: 05-13-2014
Купить DSPIC33FJ16GS402-E/SP на РадиоЛоцман.Цены — от 215 до 792 ₽11 предложений от 11 поставщиков IC MCU 16BIT 16KB FLASH 28SDIP. dsPIC Automotive, AEC-Q100, dsPICTM 33F Microcontroller IC 16-Bit 40 MIPs 16KB (16K x 8)... | |||
| DSPIC33FJ16GS402-E/SP Microchip | 345 ₽ | ||
| DSPIC33FJ16GS402-E/SP Microchip | по запросу | ||
| Корпус | SPDIP |
| Количество выводов | 28 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 16 |
| CPU | 16-bit dsPIC DSC |
| CRC/Scan | No |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| I2C | 1 |
| Internal Oscillator | 7.37 MHz, 32.768 kHz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 8 including complementary outputs |
| Max 16 Bit Digital Timers | 3 |
| Max A/D Resolution | 10 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 40 |
| Рабочий диапазон температур | от -40 до +125 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 3 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 28 |
| Размер памяти программ | 16 Kbytes |
| RAM | 2048 bytes |
| SPIв„ў | 1 |
| Temp. Range Max. | 150 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 8 |
| UART | 1 |
| Windowed Watchdog Timer | Yes WWDT |
| Zero Cross detect | No |
dsPIC33FJ16GS404 dsPIC33FJ16GS502 dsPIC33FJ16GS504
Серия: dsPIC33FJ16GS402 (16)
- DSPIC33FJ16GS402-50I/MM DSPIC33FJ16GS402-50I/SO DSPIC33FJ16GS402-50I/SP DSPIC33FJ16GS402-E/MM DSPIC33FJ16GS402-E/SO DSPIC33FJ16GS402-E/SP DSPIC33FJ16GS402-H/MM DSPIC33FJ16GS402-H/SP DSPIC33FJ16GS402-I/MM DSPIC33FJ16GS402-I/SO DSPIC33FJ16GS402-I/SP DSPIC33FJ16GS402T-50I/MM DSPIC33FJ16GS402T-50I/SO DSPIC33FJ16GS402T-E/MM DSPIC33FJ16GS402T-H/MM DSPIC33FJ16GS402T-I/MM
DSPIC33FJ16GS402E/SP, DSPIC33FJ16GS402 E/SP
