Datasheet Microchip DSPIC33FJ16GS504T-H/PT — Даташит
| Производитель | Microchip |
| Серия | dsPIC33FJ16GS504 |
| Модель | DSPIC33FJ16GS504T-H/PT |
dsPIC33FJXXGSXXX SMPS и цифровой преобразователь энергии 16-битный контроллер цифровых сигналов
dsPIC33FJ06GS101/X02 and dsPIC33FJ16GSX02/X04 Data Sheet
PDF, 3.7 Мб, Версия: 05-13-2014
16-bit MCU/DSC, 16 KB, 2048 Bytes, 40 MHz, 3 to 3.6V, TQFP-44, RoHS | |||
| DSPIC33FJ16GS504T-H/PT Microchip | 319 ₽ | ||
| DSPIC33FJ16GS504T-H/PT Microchip | по запросу | ||
| Корпус | TQFP |
| Количество выводов | 44 |
| # of Comparators | 4 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 16 |
| CPU | 16-bit dsPIC DSC |
| CRC/Scan | No |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| I2C | 1 |
| Internal Oscillator | 7.37 MHz, 32.768 kHz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 10 including complementary outputs |
| Max 16 Bit Digital Timers | 3 |
| Max A/D Resolution | 10 bits |
| Max D/A Resolution | 10 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 40 |
| Number of D/A Converters | 4 |
| Рабочий диапазон температур | от -40 до +150 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 3 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 44 |
| Размер памяти программ | 16 Kbytes |
| RAM | 2048 bytes |
| SPIв„ў | 1 |
| Temp. Range Max. | 150 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 12 |
| UART | 1 |
| Windowed Watchdog Timer | Yes WWDT |
| Zero Cross detect | No |
dsPIC33FJ16GS402 dsPIC33FJ16GS404 dsPIC33FJ16GS502
Серия: dsPIC33FJ16GS504 (24)
- DSPIC33FJ16GS504-50I/ML DSPIC33FJ16GS504-50I/PT DSPIC33FJ16GS504-50I/TL DSPIC33FJ16GS504-E/ML DSPIC33FJ16GS504-E/PT DSPIC33FJ16GS504-E/TL DSPIC33FJ16GS504-H/ML DSPIC33FJ16GS504-H/PT DSPIC33FJ16GS504-H/TL DSPIC33FJ16GS504-I/ML DSPIC33FJ16GS504-I/PT DSPIC33FJ16GS504-I/TL DSPIC33FJ16GS504T-50I/ML DSPIC33FJ16GS504T-50I/PT DSPIC33FJ16GS504T-50I/TL DSPIC33FJ16GS504T-E/ML DSPIC33FJ16GS504T-E/PT DSPIC33FJ16GS504T-E/TL DSPIC33FJ16GS504T-H/ML DSPIC33FJ16GS504T-H/PT DSPIC33FJ16GS504T-H/TL DSPIC33FJ16GS504T-I/ML DSPIC33FJ16GS504T-I/PT DSPIC33FJ16GS504T-I/TL
DSPIC33FJ16GS504TH/PT, DSPIC33FJ16GS504T H/PT
Купить DSPIC33FJ16GS504T-H/PT на РадиоЛоцман.Цены
