Datasheet Microchip DSPIC33FJ32GP302T-I/MM — Даташит
Производитель | Microchip |
Серия | dsPIC33FJ32GP302 |
Модель | DSPIC33FJ32GP302T-I/MM |
dsPIC33FJ32GP302/304, dsPIC33FJ64GPX02/X04 and dsPIC33FJ128GPX02/X04 Data Sheet
PDF, 6.3 Мб, Версия: 04-19-2012
![]() 12 предложений от 11 поставщиков IC MCU 16BIT 32KB FLASH 28QFN / dsPIC series Microcontroller IC 16-Bit 40 MIPs 32KB (32K x 8) FLASH 28-QFN-S (6x6)... | |||
DSPIC33FJ32GP302T-I/MM Microchip | 119 ₽ | ||
DSPIC33FJ32GP302T-I/MM Microchip | от 209 ₽ | ||
DSPIC33FJ32GP302T-I/MM Microchip | 802 ₽ | ||
DSPIC33FJ32GP302T-I/MM Microchip | по запросу |
Корпус | QFN-S |
Количество выводов | 28 |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | Yes |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 7.37 MHz, 32.768 kHz |
Math Accelerator | No |
Max # PWM outputs | 4 including complementary outputs |
Max D/A Resolution | 4 bits |
Max. CPU Speed MHz | 40 |
Operation Voltage Min.(V) | 3 |
Pin count | 28 |
Размер памяти программ | 32 Kbytes |
RAM | 4096 bytes |
SPIв„ў | 2 |
Temp. Range Max. | 125 |
Temp. Range Min. | -40 |
Total # of A/D channels | 10 |
UART | 2 |
Zero Cross detect | No |
dsPIC33FJ128GP202 dsPIC33FJ128GP204 dsPIC33FJ128GP802 dsPIC33FJ128GP804 dsPIC33FJ32GP304 dsPIC33FJ64GP202 dsPIC33FJ64GP204 dsPIC33FJ64GP802 dsPIC33FJ64GP804
Серия: dsPIC33FJ32GP302 (10)
DSPIC33FJ32GP302TI/MM, DSPIC33FJ32GP302T I/MM
