Datasheet Microchip DSPIC33FJ32GP304-E/ML — Даташит
СерияdsPIC33FJ32GP304
МодельDSPIC33FJ32GP304-E/ML
dsPIC33FJ32GP302/304, dsPIC33FJ64GPX02/X04 and dsPIC33FJ128GPX02/X04 Data Sheet
PDF, 6.3 Мб, Версия: 04-19-2012
IC MCU 16BIT 32KB FLASH 44QFN. dsPIC Automotive, AEC-Q100, dsPICTM 33F Microcontroller IC 16-Bit 40 MIPs 32KB (32K x 8)...
137 ₽
251 ₽
Рутоника
347 ₽
КорпусQFN
Количество выводов44
# of Comparators2
ADCC with ComputationNo
Angular TimerNo
Архитектура16
CPU16-bit dsPIC DSC
CRC/ScanYes
EEPROM / HEF0 / HEF
High Voltage CapableNo
I2C1
Internal Oscillator7.37 MHz, 32.768 kHz
Math AcceleratorNo
Max # PWM outputs4 including complementary outputs
Max 16 Bit Digital Timers5
Max A/D Resolution12 bits
Max D/A Resolution4 bits
Max PWM Resolution16 bits
Max. CPU Speed MHz40
Number of D/A Converters1
Operation Voltage Max.(V)3.6
Operation Voltage Min.(V)3
Peripheral Pin SelectYes PPS
Pin count44
Размер памяти программ32 Kbytes
RAM4096 bytes
SPIв„ў2
Temp. Range Max.125
Temp. Range Min.-40
Total # of A/D channels13
UART2
Zero Cross detectNo
dsPIC33FJ128GP202 dsPIC33FJ128GP204 dsPIC33FJ128GP802 dsPIC33FJ128GP804 dsPIC33FJ32GP302 dsPIC33FJ64GP202 dsPIC33FJ64GP204 dsPIC33FJ64GP802 dsPIC33FJ64GP804
DSPIC33FJ32GP304E/ML, DSPIC33FJ32GP304 E/ML
На английском языке: Datasheet Microchip DSPIC33FJ32GP304-E/ML
