Datasheet Microchip DSPIC33FJ32GP304T-I/ML — Даташит
СерияdsPIC33FJ32GP304
МодельDSPIC33FJ32GP304T-I/ML
dsPIC33FJ32GP302/304, dsPIC33FJ64GPX02/X04 and dsPIC33FJ128GPX02/X04 Data Sheet
PDF, 6.3 Мб, Версия: 04-19-2012
Микросхема Микроконтроллер, MCU 16Bit dSPIC33 dsPIC RISC 32KB Flash 3.3V 44Pin QFN EP T/R
237 ₽
462 ₽
Hi-Tech Circuit Group
КорпусQFN
Количество выводов44
# of Comparators2
ADCC with ComputationNo
Angular TimerNo
Архитектура16
CPU16-bit dsPIC DSC
CRC/ScanYes
EEPROM / HEF0 / HEF
High Voltage CapableNo
I2C1
Internal Oscillator7.37 MHz, 32.768 kHz
Math AcceleratorNo
Max # PWM outputs4 including complementary outputs
Max 16 Bit Digital Timers5
Max A/D Resolution12 bits
Max D/A Resolution4 bits
Max PWM Resolution16 bits
Max. CPU Speed MHz40
Number of D/A Converters1
Operation Voltage Max.(V)3.6
Operation Voltage Min.(V)3
Peripheral Pin SelectYes PPS
Pin count44
Размер памяти программ32 Kbytes
RAM4096 bytes
SPIв„ў2
Temp. Range Max.125
Temp. Range Min.-40
Total # of A/D channels13
UART2
Zero Cross detectNo
dsPIC33FJ128GP202 dsPIC33FJ128GP204 dsPIC33FJ128GP802 dsPIC33FJ128GP804 dsPIC33FJ32GP302 dsPIC33FJ64GP202 dsPIC33FJ64GP204 dsPIC33FJ64GP802 dsPIC33FJ64GP804
DSPIC33FJ32GP304TI/ML, DSPIC33FJ32GP304T I/ML
На английском языке: Datasheet Microchip DSPIC33FJ32GP304T-I/ML
