Datasheet Microchip DSPIC33FJ32GS606-50I/MR — Даташит
| Производитель | Microchip |
| Серия | dsPIC33FJ32GS606 |
| Модель | DSPIC33FJ32GS606-50I/MR |
dsPIC33FJXXGSXXX SMPS и цифровой преобразователь энергии 16-битный контроллер цифровых сигналов
dsPIC33FJ32GS406/606/608/610 and dsPIC33FJ64GS406/606/608/610 Data Sheet
PDF, 3.7 Мб, Версия: 07-14-2014
Купить DSPIC33FJ32GS606-50I/MR на РадиоЛоцман.Цены — от 155 до 1 371 ₽15 предложений от 13 поставщиков IC MCU 16BIT 32KB FLASH 64QFN. dsPIC dsPICTM 33F Microcontroller IC 16-Bit 50 MIPs 32KB (32K x 8) FLASH 64-QFN... | |||
| DSPIC33FJ32GS606-50I/MR Microchip | 283 ₽ | ||
| DSPIC33FJ32GS606-50I/MR Microchip | по запросу | ||
| Корпус | QFN |
| Количество выводов | 64 |
| # of Comparators | 4 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 16 |
| CPU | 16-bit dsPIC DSC |
| CRC/Scan | No |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| I2C | 2 |
| Internal Oscillator | 7.37 MHz, 32.768 kHz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 16 including complementary outputs |
| Max 16 Bit Digital Timers | 5 |
| Max A/D Resolution | 10 bits |
| Max D/A Resolution | 10 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 40 |
| Number of D/A Converters | 4 |
| Рабочий диапазон температур | от -40 до +85 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 3 |
| Peripheral Pin Select | No PPS |
| Pin count | 64 |
| Размер памяти программ | 32 Kbytes |
| RAM | 4096 bytes |
| SPIв„ў | 2 |
| Temp. Range Max. | 125 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 16 |
| UART | 2 |
| Windowed Watchdog Timer | Yes WWDT |
| Zero Cross detect | No |
dsPIC33FJ32GS406 dsPIC33FJ32GS608 dsPIC33FJ32GS610 dsPIC33FJ64GS406 dsPIC33FJ64GS606 dsPIC33FJ64GS608 dsPIC33FJ64GS610
Серия: dsPIC33FJ32GS606 (10)
DSPIC33FJ32GS60650I/MR, DSPIC33FJ32GS606 50I/MR
