Datasheet Microchip DSPIC33FJ32GS606-I/MR — Даташит
СерияdsPIC33FJ32GS606
МодельDSPIC33FJ32GS606-I/MR
dsPIC33FJXXGSXXX SMPS и цифровой преобразователь энергии 16-битный контроллер цифровых сигналов
dsPIC33FJ32GS406/606/608/610 and dsPIC33FJ64GS406/606/608/610 Data Sheet
PDF, 3.7 Мб, Версия: 07-14-2014
IC MCU 16BIT 32KB FLASH 64QFN. dsPIC dsPICTM 33F Microcontroller IC 16-Bit 40 MIPs 32KB (32K x 8) FLASH 64-QFN...
от 139 ₽
Hi-Tech Circuit Group
727GS
КорпусQFN
Количество выводов64
# of Comparators4
ADCC with ComputationNo
Angular TimerNo
Архитектура16
CPU16-bit dsPIC DSC
CRC/ScanNo
EEPROM / HEF0 / HEF
High Voltage CapableNo
I2C2
Internal Oscillator7.37 MHz, 32.768 kHz
Math AcceleratorNo
Max # PWM outputs16 including complementary outputs
Max 16 Bit Digital Timers5
Max A/D Resolution10 bits
Max D/A Resolution10 bits
Max PWM Resolution16 bits
Max. CPU Speed MHz40
Number of D/A Converters4
Operation Voltage Max.(V)3.6
Operation Voltage Min.(V)3
Peripheral Pin SelectNo PPS
Pin count64
Размер памяти программ32 Kbytes
RAM4096 bytes
SPIв„ў2
Temp. Range Max.125
Temp. Range Min.-40
Total # of A/D channels16
UART2
Zero Cross detectNo
dsPIC33FJ32GS406 dsPIC33FJ32GS608 dsPIC33FJ32GS610 dsPIC33FJ64GS406 dsPIC33FJ64GS606 dsPIC33FJ64GS608 dsPIC33FJ64GS610
DSPIC33FJ32GS606I/MR, DSPIC33FJ32GS606 I/MR
На английском языке: Datasheet Microchip DSPIC33FJ32GS606-I/MR
