Datasheet Microchip DSPIC33FJ64GP202T-E/MMVAO — Даташит
| Производитель | Microchip |
| Серия | dsPIC33FJ64GP202 |
| Модель | DSPIC33FJ64GP202T-E/MMVAO |
dsPIC33FJ32GP302/304, dsPIC33FJ64GPX02/X04 and dsPIC33FJ128GPX02/X04 Data Sheet
PDF, 6.3 Мб, Версия: 04-19-2012
 Купить DSPIC33FJ64GP202T-E на РадиоЛоцман.Цены — от 130 до 859 ₽14 предложений от 14 поставщиков IC MCU 16BIT 64KB FLASH 28SOIC. dsPIC dsPICTM 33F Microcontroller IC 16-Bit 40 MIPs 64KB (64K x 8) FLASH 28-SOIC....  | |||
| DSPIC33FJ64GP202T-I/SO | 307 ₽ | ||
| DSPIC33FJ64GP202T-I/SO Microchip  | 322 ₽ | ||
| DSPIC33FJ64GP202T-I/SO Microchip  | 455 ₽ | ||
| DSPIC33FJ64GP202T-I/SO Microchip  | по запросу | ||
| Корпус | QFN-S |
| Количество выводов | 28 |
| # of Comparators | 2 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 16 |
| CPU | 16-bit dsPIC DSC |
| CRC/Scan | Yes |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| I2C | 1 |
| Internal Oscillator | 7.37 MHz, 32.768 kHz |
| Internal Voltage Reference | No Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 4 including complementary outputs |
| Max 16 Bit Digital Timers | 5 |
| Max A/D Resolution | 12 bits |
| Max D/A Resolution | 4 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 40 |
| Number of D/A Converters | 1 |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 3 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 28 |
| Размер памяти программ | 64 Kbytes |
| RAM | 8192 bytes |
| SPIв„ў | 2 |
| Temp. Range Max. | 125 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 10 |
| UART | 2 |
| Windowed Watchdog Timer | Yes WWDT |
| Zero Cross detect | No |
dsPIC33FJ128GP202 dsPIC33FJ128GP204 dsPIC33FJ128GP802 dsPIC33FJ128GP804 dsPIC33FJ32GP302 dsPIC33FJ32GP304 dsPIC33FJ64GP204 dsPIC33FJ64GP802 dsPIC33FJ64GP804
Серия: dsPIC33FJ64GP202 (11)
DSPIC33FJ64GP202TE/MMVAO, DSPIC33FJ64GP202T E/MMVAO
