Datasheet Microchip DSPIC33FJ64GS406-E/MR — Даташит
| Производитель | Microchip |
| Серия | dsPIC33FJ64GS406 |
| Модель | DSPIC33FJ64GS406-E/MR |
dsPIC33FJXXGSXXX SMPS и цифровой преобразователь энергии 16-битный контроллер цифровых сигналов
dsPIC33FJ32GS406/606/608/610 and dsPIC33FJ64GS406/606/608/610 Data Sheet
PDF, 3.7 Мб, Версия: 07-14-2014
 Купить DSPIC33FJ64GS406-E/MR на РадиоЛоцман.Цены — от 278 до 1 522 ₽13 предложений от 11 поставщиков IC MCU 16BIT 64KB FLASH 64QFN. dsPIC Automotive, AEC-Q100, dsPICTM 33F Microcontroller IC 16-Bit 40 MIPs 64KB (64K x 8)...  | |||
| DSPIC33FJ64GS406-E/MR Microchip  | 383 ₽ | ||
| DSPIC33FJ64GS406-E/MR Microchip  | 507 ₽ | ||
| DSPIC33FJ64GS406-E/MR Microchip  | по запросу | ||
| Корпус | QFN |
| Количество выводов | 64 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 16 |
| CPU | 16-bit dsPIC DSC |
| CRC/Scan | No |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| I2C | 2 |
| Internal Oscillator | 7.37 MHz, 32.768 kHz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 16 including complementary outputs |
| Max 16 Bit Digital Timers | 5 |
| Max A/D Resolution | 10 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 40 |
| Рабочий диапазон температур | от -40 до +125 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 3 |
| Peripheral Pin Select | No PPS |
| Pin count | 64 |
| Размер памяти программ | 64 Kbytes |
| RAM | 8192 bytes |
| SPIв„ў | 2 |
| Temp. Range Max. | 125 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 16 |
| UART | 2 |
| Windowed Watchdog Timer | Yes WWDT |
| Zero Cross detect | No |
dsPIC33FJ32GS406 dsPIC33FJ32GS606 dsPIC33FJ32GS608 dsPIC33FJ32GS610 dsPIC33FJ64GS606 dsPIC33FJ64GS608 dsPIC33FJ64GS610
Серия: dsPIC33FJ64GS406 (10)
DSPIC33FJ64GS406E/MR, DSPIC33FJ64GS406 E/MR
