Datasheet Microchip DSPIC33FJ64GS606T-50I/PTVAO — Даташит
Производитель | Microchip |
Серия | dsPIC33FJ64GS606 |
Модель | DSPIC33FJ64GS606T-50I/PTVAO |
dsPIC33FJXXGSXXX SMPS и цифровой преобразователь энергии 16-битный контроллер цифровых сигналов
dsPIC33FJ32GS406/606/608/610 and dsPIC33FJ64GS406/606/608/610 Data Sheet
PDF, 3.7 Мб, Версия: 07-14-2014
DSPIC33FJ64GS606T-50I/PTVAO Microchip | 354 ₽ |
Корпус | TQFP |
Количество выводов | 64 |
# of Comparators | 4 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | No |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 2 |
Internal Oscillator | 7.37 MHz, 32.768 kHz |
Math Accelerator | No |
Max # PWM outputs | 16 including complementary outputs |
Max A/D Resolution | 10 bits |
Max D/A Resolution | 10 bits |
Max. CPU Speed MHz | 40 |
Number of D/A Converters | 4 |
Operation Voltage Min.(V) | 3 |
Peripheral Pin Select | No PPS |
Pin count | 64 |
Размер памяти программ | 64 Kbytes |
RAM | 9216 bytes |
SPIв„ў | 2 |
Temp. Range Max. | 125 |
Temp. Range Min. | -40 |
Total # of A/D channels | 16 |
UART | 2 |
Zero Cross detect | No |
dsPIC33FJ32GS406 dsPIC33FJ32GS606 dsPIC33FJ32GS608 dsPIC33FJ32GS610 dsPIC33FJ64GS406 dsPIC33FJ64GS608 dsPIC33FJ64GS610
Серия: dsPIC33FJ64GS606 (13)
- DSPIC33FJ64GS606-50I/MR DSPIC33FJ64GS606-50I/PT DSPIC33FJ64GS606-50I/PTVAO DSPIC33FJ64GS606-E/MR DSPIC33FJ64GS606-E/MRVAO DSPIC33FJ64GS606-E/PT DSPIC33FJ64GS606-I/MR DSPIC33FJ64GS606-I/PT DSPIC33FJ64GS606T-50I/MR DSPIC33FJ64GS606T-50I/PT DSPIC33FJ64GS606T-50I/PTVAO DSPIC33FJ64GS606T-E/PT DSPIC33FJ64GS606T-I/PT
DSPIC33FJ64GS606T50I/PTVAO, DSPIC33FJ64GS606T 50I/PTVAO
