Datasheet Microchip DSPIC33FJ64MC802T-H/MM — Даташит
Производитель | Microchip |
Серия | dsPIC33FJ64MC802 |
Модель | DSPIC33FJ64MC802T-H/MM |
dsPIC33FJ32MC302/304, dsPIC33FJ64MCX02/X04 and dsPIC33FJ128MCX02/X04 Data Sheet
PDF, 6.6 Мб, Версия: 04-19-2012
, 16Bit MCU/DSP 40MIPS 64KB FLASH | |||
DSPIC33FJ64MC802T-H/MM Microchip | 343 ₽ | ||
DSPIC33FJ64MC802T-H/MM Microchip | по запросу |
Корпус | QFN-S |
Количество выводов | 28 |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 16 |
CPU | 16-bit dsPIC DSC |
CRC/Scan | Yes |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 7.37 MHz, 32.768 kHz |
Math Accelerator | No |
Max # PWM outputs | 12 including complementary outputs |
Max D/A Resolution | 4 bits |
Max. CPU Speed MHz | 40 |
Рабочий диапазон температур | от -40 до +150 °C |
Operation Voltage Min.(V) | 3 |
Pin count | 28 |
Размер памяти программ | 64 Kbytes |
RAM | 16384 bytes |
SPIв„ў | 2 |
Temp. Range Max. | 150 |
Temp. Range Min. | -40 |
Total # of A/D channels | 6 |
UART | 2 |
Zero Cross detect | No |
dsPIC33FJ128MC202 dsPIC33FJ128MC204 dsPIC33FJ128MC802 dsPIC33FJ128MC804 dsPIC33FJ32MC302 dsPIC33FJ32MC304 dsPIC33FJ64MC202 dsPIC33FJ64MC204 dsPIC33FJ64MC804
Серия: dsPIC33FJ64MC802 (14)
- DSPIC33FJ64MC802-E/MM DSPIC33FJ64MC802-E/SO DSPIC33FJ64MC802-E/SP DSPIC33FJ64MC802-H/MM DSPIC33FJ64MC802-H/SO DSPIC33FJ64MC802-I/MM DSPIC33FJ64MC802-I/SO DSPIC33FJ64MC802-I/SP DSPIC33FJ64MC802T-E/MM DSPIC33FJ64MC802T-E/SO DSPIC33FJ64MC802T-H/MM DSPIC33FJ64MC802T-H/SO DSPIC33FJ64MC802T-I/MM DSPIC33FJ64MC802T-I/SO
DSPIC33FJ64MC802TH/MM, DSPIC33FJ64MC802T H/MM
