Datasheet Microchip DSPIC33FJ64MC802T-I/MM — Даташит
СерияdsPIC33FJ64MC802
МодельDSPIC33FJ64MC802T-I/MM
dsPIC33FJ32MC302/304, dsPIC33FJ64MCX02/X04 and dsPIC33FJ128MCX02/X04 Data Sheet
PDF, 6.6 Мб, Версия: 04-19-2012
Микросхема Микроконтроллер, MCU 16Bit dSPIC33 dsPIC RISC 64KB Flash 3.3V 28Pin QFN-S EP T/R
361 ₽
534 ₽
Hi-Tech Circuit Group
КорпусQFN-S
Количество выводов28
# of Comparators2
ADCC with ComputationNo
Angular TimerNo
Архитектура16
CPU16-bit dsPIC DSC
CRC/ScanYes
EEPROM / HEF0 / HEF
High Voltage CapableNo
I2C1
Internal Oscillator7.37 MHz, 32.768 kHz
Math AcceleratorNo
Max # PWM outputs12 including complementary outputs
Max 16 Bit Digital Timers5
Max A/D Resolution12 bits
Max D/A Resolution4 bits
Max PWM Resolution16 bits
Max. CPU Speed MHz40
Number of D/A Converters1
Operation Voltage Max.(V)3.6
Operation Voltage Min.(V)3
Peripheral Pin SelectYes PPS
Pin count28
Размер памяти программ64 Kbytes
RAM16384 bytes
SPIв„ў2
Temp. Range Max.150
Temp. Range Min.-40
Total # of A/D channels6
UART2
Zero Cross detectNo
dsPIC33FJ128MC202 dsPIC33FJ128MC204 dsPIC33FJ128MC802 dsPIC33FJ128MC804 dsPIC33FJ32MC302 dsPIC33FJ32MC304 dsPIC33FJ64MC202 dsPIC33FJ64MC204 dsPIC33FJ64MC804
DSPIC33FJ64MC802TI/MM, DSPIC33FJ64MC802T I/MM
На английском языке: Datasheet Microchip DSPIC33FJ64MC802T-I/MM
