Datasheet Microchip DSPIC33FJ64MC804-H/PT — Даташит
СерияdsPIC33FJ64MC804
МодельDSPIC33FJ64MC804-H/PT
dsPIC33FJ32MC302/304, dsPIC33FJ64MCX02/X04 and dsPIC33FJ128MCX02/X04 Data Sheet
PDF, 6.6 Мб, Версия: 04-19-2012
IC MCU 16BIT 64KB FLASH 44TQFP. dsPIC Automotive, AEC-Q100, dsPICTM 33F Microcontroller IC 16-Bit 20 MIPS 64KB (64K x 8)...
773 ₽
1 397 ₽
Hi-Tech Circuit Group
КорпусTQFP
Количество выводов44
# of Comparators2
ADCC with ComputationNo
Angular TimerNo
Архитектура16
CPU16-bit dsPIC DSC
CRC/ScanYes
EEPROM / HEF0 / HEF
High Voltage CapableNo
I2C1
Internal Oscillator7.37 MHz, 32.768 kHz
Math AcceleratorNo
Max # PWM outputs12 including complementary outputs
Max 16 Bit Digital Timers5
Max A/D Resolution12 bits
Max D/A Resolution16 bits
Max PWM Resolution16 bits
Max. CPU Speed MHz40
Number of D/A Converters2
Рабочий диапазон температурот -40 до +150 °C
Operation Voltage Max.(V)3.6
Operation Voltage Min.(V)3
Peripheral Pin SelectYes PPS
Pin count44
Размер памяти программ64 Kbytes
RAM16384 bytes
SPIв„ў2
Temp. Range Max.150
Temp. Range Min.-40
Total # of A/D channels9
UART2
Zero Cross detectNo
dsPIC33FJ128MC202 dsPIC33FJ128MC204 dsPIC33FJ128MC802 dsPIC33FJ128MC804 dsPIC33FJ32MC302 dsPIC33FJ32MC304 dsPIC33FJ64MC202 dsPIC33FJ64MC204 dsPIC33FJ64MC802
DSPIC33FJ64MC804H/PT, DSPIC33FJ64MC804 H/PT
На английском языке: Datasheet Microchip DSPIC33FJ64MC804-H/PT
