Datasheet Microchip PIC32MM0016GPL028-I/SO — Даташит
Производитель | Microchip |
Серия | PIC32MM0016GPL028 |
Модель | PIC32MM0016GPL028-I/SO |
Семейство PIC32MM — это самое экономичное и экономичное семейство 32-разрядных микроконтроллеров PIC32 компании Microchip.
![]() 10 предложений от 9 поставщиков Микросхема Микроконтроллер 32, 16KB Flash, 4KB Ram, 79 Coremark At 25MHz, Low Power Micromips 28 Soic 0.3in Tube | |||
PIC32MM0016GPL028-I/SO Microchip | 37 ₽ | ||
PIC32MM0016GPL028-I/SO Microchip | 73 ₽ | ||
PIC32MM0016GPL028-I/SO | 95 ₽ | ||
PIC32MM0016GPL028-I/SO Microchip | по запросу |
Корпус | SOIC |
Количество выводов | 28 |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | 32-bit MIPS MCU |
CRC/Scan | Yes |
Configurable Logic Cell Modules | 2 CLC |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
Math Accelerator | No |
Max # PWM outputs | 8 including complementary outputs |
Max 16 Bit Digital Timers | 7 |
Max D/A Resolution | 5 bits |
Max. CPU Speed MHz | 25 |
Operation Voltage Min.(V) | 2 |
Pin count | 28 |
Размер памяти программ | 16 Kbytes |
RAM | 4096 bytes |
SPIв„ў | 2 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 12 |
UART | 2 |
Zero Cross detect | No |
PIC32MM0016GPL020 PIC32MM0016GPL036 PIC32MM0032GPL020 PIC32MM0032GPL028 PIC32MM0032GPL036 PIC32MM0064GPL020 PIC32MM0064GPL028 PIC32MM0064GPL036
Серия: PIC32MM0016GPL028 (8)
PIC32MM0016GPL028I/SO, PIC32MM0016GPL028 I/SO
