Datasheet Microchip PIC32MM0032GPL020-I/SS — Даташит
Производитель | Microchip |
Серия | PIC32MM0032GPL020 |
Модель | PIC32MM0032GPL020-I/SS |
Семейство PIC32MM — это самое экономичное и экономичное семейство 32-разрядных микроконтроллеров PIC32 компании Microchip.
![]() 23 предложений от 14 поставщиков IC MCU 32BIT 32KB FLASH 20SSOP. MIPS32® microAptivTM PIC® 32MM Microcontroller IC 32-Bit 25MHz 32KB (32K x 8) FLASH 20-SSOP.... | |||
PIC32MM0032GPL020-I/SS Microchip | от 36 ₽ | ||
PIC32MM0032GPL020-I/SS | 113 ₽ | ||
PIC32MM0032GPL020-I/SS Microchip | 132 ₽ | ||
PIC32MM0032GPL020-I/SS Microchip | по запросу |
Корпус | SSOP |
Количество выводов | 20 |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | 32-bit MIPS MCU |
CRC/Scan | Yes |
Configurable Logic Cell Modules | 2 CLC |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
Math Accelerator | No |
Max # PWM outputs | 8 including complementary outputs |
Max 16 Bit Digital Timers | 7 |
Max D/A Resolution | 5 bits |
Max. CPU Speed MHz | 25 |
Operation Voltage Min.(V) | 2 |
Pin count | 20 |
Размер памяти программ | 32 Kbytes |
RAM | 8192 bytes |
SPIв„ў | 2 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 11 |
UART | 2 |
Zero Cross detect | No |
PIC32MM0016GPL020 PIC32MM0016GPL028 PIC32MM0016GPL036 PIC32MM0032GPL028 PIC32MM0032GPL036 PIC32MM0064GPL020 PIC32MM0064GPL028 PIC32MM0064GPL036
Серия: PIC32MM0032GPL020 (4)
- PIC32MM0032GPL020-I/ML PIC32MM0032GPL020-I/SS PIC32MM0032GPL020T-I/ML PIC32MM0032GPL020T-I/SS
PIC32MM0032GPL020I/SS, PIC32MM0032GPL020 I/SS
