Datasheet Microchip PIC32MM0032GPL036T-I/M2 — Даташит
Производитель | Microchip |
Серия | PIC32MM0032GPL036 |
Модель | PIC32MM0032GPL036T-I/M2 |
Семейство PIC32MM — это самое экономичное и экономичное семейство 32-разрядных микроконтроллеров PIC32 компании Microchip.
![]() 5 предложений от 5 поставщиков , 32KB Flash, 8KB Ram, 79 Coremark At 25MHz, Low Power Micromips 36 Sqfn 6x6x1.0mm t/r | |||
PIC32MM0032GPL036T-I/M2 Microchip | 47 ₽ | ||
PIC32MM0032GPL036T-I/M2 Microchip | 119 ₽ | ||
PIC32MM0032GPL036T-I/M2 Microchip | по запросу | ||
Корпус | SQFN |
Количество выводов | 36 |
# of Comparators | 2 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | 32-bit MIPS MCU |
CRC/Scan | Yes |
Configurable Logic Cell Modules | 2 CLC |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
Math Accelerator | No |
Max # PWM outputs | 8 including complementary outputs |
Max 16 Bit Digital Timers | 7 |
Max D/A Resolution | 5 bits |
Max. CPU Speed MHz | 25 |
Operation Voltage Min.(V) | 2 |
Pin count | 36 |
Размер памяти программ | 32 Kbytes |
RAM | 8192 bytes |
SPIв„ў | 2 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 14 |
UART | 2 |
Zero Cross detect | No |
PIC32MM0016GPL020 PIC32MM0016GPL028 PIC32MM0016GPL036 PIC32MM0032GPL020 PIC32MM0032GPL028 PIC32MM0064GPL020 PIC32MM0064GPL028 PIC32MM0064GPL036
Серия: PIC32MM0032GPL036 (4)
- PIC32MM0032GPL036-I/M2 PIC32MM0032GPL036-I/MV PIC32MM0032GPL036T-I/M2 PIC32MM0032GPL036T-I/MV
PIC32MM0032GPL036TI/M2, PIC32MM0032GPL036T I/M2
