Datasheet Microchip PIC32MM0064GPL028-I/ML — Даташит
| Производитель | Microchip |
| Серия | PIC32MM0064GPL028 |
| Модель | PIC32MM0064GPL028-I/ML |
Семейство PIC32MM — это самое экономичное и экономичное семейство 32-разрядных микроконтроллеров PIC32 компании Microchip.
 Купить PIC32MM0064GPL028-I/ML на РадиоЛоцман.Цены — от 43 до 509 ₽20 предложений от 14 поставщиков IC MCU 32BIT 64KB FLASH 28QFN. MIPS32® microAptivTM PIC® 32MM Microcontroller IC 32-Bit 25MHz 64KB (64K x 8) FLASH 28-QFN...  | |||
| PIC32MM0064GPL028-I/ML Microchip  | от 43 ₽ | ||
| PIC32MM0064GPL028-I/ML Microchip  | 79 ₽ | ||
| PIC32MM0064GPL028-I/ML Microchip  | 104 ₽ | ||
| PIC32MM0064GPL028-I/ML Microchip  | от 505 ₽ | ||
| Корпус | QFN |
| Количество выводов | 28 |
| # of Comparators | 2 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 32 |
| CPU | 32-bit MIPS MCU |
| CRC/Scan | Yes |
| Configurable Logic Cell Modules | 2 CLC |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| Internal Oscillator | 8 MHz, 32 kHz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 8 including complementary outputs |
| Max 16 Bit Digital Timers | 7 |
| Max A/D Resolution | 12 bits |
| Max D/A Resolution | 5 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 25 |
| Number of D/A Converters | 1 |
| Рабочий диапазон температур | от -40 до +85 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 2 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 28 |
| Размер памяти программ | 64 Kbytes |
| RAM | 8192 bytes |
| SPIв„ў | 2 |
| Temp. Range Max. | 85 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 12 |
| UART | 2 |
| Windowed Watchdog Timer | Yes WWDT |
| Zero Cross detect | No |
PIC32MM0016GPL020 PIC32MM0016GPL028 PIC32MM0016GPL036 PIC32MM0032GPL020 PIC32MM0032GPL028 PIC32MM0032GPL036 PIC32MM0064GPL020 PIC32MM0064GPL036
Серия: PIC32MM0064GPL028 (9)
PIC32MM0064GPL028I/ML, PIC32MM0064GPL028 I/ML
