Datasheet Microchip PIC32MM0128GPM036T-I/MV — Даташит
Производитель | Microchip |
Серия | PIC32MM0128GPM036 |
Модель | PIC32MM0128GPM036T-I/MV |
Краткое содержание:
![]() 5 предложений от 5 поставщиков MIPS32? microAptiv? PIC? 32MM Microcontroller IC 32-Bit 25MHz 128KB (128K x 8) FLASH 40-UQFN (5x5) | |||
PIC32MM0128GPM036T-I/MV Microchip | 64 ₽ | ||
PIC32MM0128GPM036T-I/MV Microchip | 162 ₽ | ||
PIC32MM0128GPM036T-I/MV Microchip | по запросу | ||
Корпус | UQFN |
Количество выводов | 40 |
# of Comparators | 3 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | 32-bit MIPS MCU |
CRC/Scan | Yes |
Configurable Logic Cell Modules | 4 CLC |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 3 |
Math Accelerator | No |
Max # PWM outputs | 20 including complementary outputs |
Max 16 Bit Digital Timers | 21 |
Max D/A Resolution | 5 bits |
Max. CPU Speed MHz | 25 |
Number of USB Modules | 1 |
Operation Voltage Min.(V) | 2 |
Pin count | 36 |
Размер памяти программ | 128 Kbytes |
RAM | 16384 bytes |
SPIв„ў | 3 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 15 |
UART | 3 |
Zero Cross detect | No |
PIC32MM0064GPM028 PIC32MM0064GPM036 PIC32MM0064GPM048 PIC32MM0064GPM064 PIC32MM0128GPM028 PIC32MM0128GPM048 PIC32MM0128GPM064 PIC32MM0256GPM028 PIC32MM0256GPM036 PIC32MM0256GPM048 PIC32MM0256GPM064
Серия: PIC32MM0128GPM036 (4)
- PIC32MM0128GPM036-I/M2 PIC32MM0128GPM036-I/MV PIC32MM0128GPM036T-I/M2 PIC32MM0128GPM036T-I/MV
PIC32MM0128GPM036TI/MV, PIC32MM0128GPM036T I/MV
