Datasheet Microchip PIC32MM0128GPM048-I/PT — Даташит
| Производитель | Microchip |
| Серия | PIC32MM0128GPM048 |
| Модель | PIC32MM0128GPM048-I/PT |
Краткое содержание:
Купить PIC32MM0128GPM048-I/PT на РадиоЛоцман.Цены — от 61 до 469 ₽24 предложений от 14 поставщиков IC MCU 32BIT 128KB FLASH 48TQFP. MIPS32® microAptivTM PIC® 32MM Microcontroller IC 32-Bit 25MHz 128KB (128K x 8) FLASH 48-TQFP-EP... | |||
| PIC32MM0128GPM048-I/PT Microchip | 68 ₽ | ||
| PIC32MM0128GPM048-I/PT Microchip | 150 ₽ | ||
| PIC32MM0128GPM048-I/PT | 189 ₽ | ||
| PIC32MM0128GPM048-I/PT Microchip | по запросу | ||
| Корпус | TQFP |
| Количество выводов | 48 |
| # of Comparators | 3 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 32 |
| CPU | 32-bit MIPS MCU |
| CRC/Scan | Yes |
| Configurable Logic Cell Modules | 4 CLC |
| EEPROM / HEF | 0 / HEF |
| High Voltage Capable | No |
| I2C | 3 |
| Internal Oscillator | 8 MHz, 32 kHz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | No |
| Max # PWM outputs | 24 including complementary outputs |
| Max 16 Bit Digital Timers | 21 |
| Max A/D Resolution | 12 bits |
| Max D/A Resolution | 5 bits |
| Max PWM Resolution | 16 bits |
| Max. CPU Speed MHz | 25 |
| Number of D/A Converters | 1 |
| Number of USB Modules | 1 |
| Рабочий диапазон температур | от -40 до +85 °C |
| Operation Voltage Max.(V) | 3.6 |
| Operation Voltage Min.(V) | 2 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 48 |
| Размер памяти программ | 128 Kbytes |
| RAM | 16384 bytes |
| SPIв„ў | 3 |
| Temp. Range Max. | 85 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 17 |
| UART | 3 |
| Windowed Watchdog Timer | Yes WWDT |
| Zero Cross detect | No |
PIC32MM0064GPM028 PIC32MM0064GPM036 PIC32MM0064GPM048 PIC32MM0064GPM064 PIC32MM0128GPM028 PIC32MM0128GPM036 PIC32MM0128GPM064 PIC32MM0256GPM028 PIC32MM0256GPM036 PIC32MM0256GPM048 PIC32MM0256GPM064
Серия: PIC32MM0128GPM048 (4)
- PIC32MM0128GPM048-I/M4 PIC32MM0128GPM048-I/PT PIC32MM0128GPM048T-I/M4 PIC32MM0128GPM048T-I/PT
PIC32MM0128GPM048I/PT, PIC32MM0128GPM048 I/PT
