Datasheet Microchip PIC32MM0128GPM064-I/PT — Даташит
Производитель | Microchip |
Серия | PIC32MM0128GPM064 |
Модель | PIC32MM0128GPM064-I/PT |
Краткое содержание:
![]() 18 предложений от 10 поставщиков Встраиваемые/Интегральные микросхемы | |||
PIC32MM0128GPM064-I/PT Microchip | от 182 ₽ | ||
PIC32MM0128GPM064-I/PT Microchip | 420 ₽ | ||
PIC32MM0128GPM064-I/PT Microchip | от 432 ₽ | ||
PIC32MM0128GPM064-I/PT Microchip | от 463 ₽ |
Корпус | TQFP |
Количество выводов | 64 |
# of Comparators | 3 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | 32-bit MIPS MCU |
CRC/Scan | Yes |
Configurable Logic Cell Modules | 4 CLC |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 3 |
Math Accelerator | No |
Max # PWM outputs | 24 including complementary outputs |
Max 16 Bit Digital Timers | 21 |
Max D/A Resolution | 5 bits |
Max. CPU Speed MHz | 25 |
Number of USB Modules | 1 |
Operation Voltage Min.(V) | 2 |
Pin count | 64 |
Размер памяти программ | 128 Kbytes |
RAM | 16384 bytes |
SPIв„ў | 3 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 20 |
UART | 3 |
Zero Cross detect | No |
PIC32MM0064GPM028 PIC32MM0064GPM036 PIC32MM0064GPM048 PIC32MM0064GPM064 PIC32MM0128GPM028 PIC32MM0128GPM036 PIC32MM0128GPM048 PIC32MM0256GPM028 PIC32MM0256GPM036 PIC32MM0256GPM048 PIC32MM0256GPM064
Серия: PIC32MM0128GPM064 (4)
- PIC32MM0128GPM064-I/MR PIC32MM0128GPM064-I/PT PIC32MM0128GPM064T-I/MR PIC32MM0128GPM064T-I/PT
PIC32MM0128GPM064I/PT, PIC32MM0128GPM064 I/PT
