Datasheet Microchip PIC32MM0128GPM064T-I/PT — Даташит
СерияPIC32MM0128GPM064
МодельPIC32MM0128GPM064T-I/PT
Краткое содержание:
PIC32MM0256GPM064 Family Data Sheet
PDF, 4.3 Мб, Версия: 05-25-2017
25 предложений от 13 поставщиков
IC MCU 32BIT 128KB FLASH 64TQFP. MIPS32® microAptivTM PIC® 32MM Microcontroller IC 32-Bit 25MHz 128KB (128K x 8) FLASH 64-TQFP...
71 ₽
Рутоника
160 ₽
Эиком
от 464 ₽
КорпусTQFP
Количество выводов64
# of Comparators3
ADCC with ComputationNo
Angular TimerNo
Архитектура32
CPU32-bit MIPS MCU
CRC/ScanYes
Configurable Logic Cell Modules4 CLC
EEPROM / HEF0 / HEF
High Voltage CapableNo
I2C3
Math AcceleratorNo
Max # PWM outputs24 including complementary outputs
Max 16 Bit Digital Timers21
Max A/D Resolution12 bits
Max D/A Resolution5 bits
Max PWM Resolution16 bits
Max. CPU Speed MHz25
Number of D/A Converters1
Number of USB Modules1
Operation Voltage Max.(V)3.6
Operation Voltage Min.(V)2
Peripheral Pin SelectYes PPS
Pin count64
Размер памяти программ128 Kbytes
RAM16384 bytes
SPIв„ў3
Temp. Range Max.85
Temp. Range Min.-40
Total # of A/D channels20
UART3
Zero Cross detectNo
PIC32MM0064GPM028 PIC32MM0064GPM036 PIC32MM0064GPM048 PIC32MM0064GPM064 PIC32MM0128GPM028 PIC32MM0128GPM036 PIC32MM0128GPM048 PIC32MM0256GPM028 PIC32MM0256GPM036 PIC32MM0256GPM048 PIC32MM0256GPM064
PIC32MM0128GPM064TI/PT, PIC32MM0128GPM064T I/PT
На английском языке: Datasheet Microchip PIC32MM0128GPM064T-I/PT
