Datasheet Microchip PIC32MM0256GPM028-I/ML — Даташит
Производитель | Microchip |
Серия | PIC32MM0256GPM028 |
Модель | PIC32MM0256GPM028-I/ML |
Краткое содержание:
![]() 25 предложений от 16 поставщиков IC MCU 32BIT 256KB FLASH 28QFN. MIPS32® microAptivTM PIC® 32MM Microcontroller IC 32-Bit 25MHz 256KB (256K x 8) FLASH 28-QFN... | |||
PIC32MM0256GPM028-I/ML Microchip | от 36 ₽ | ||
PIC32MM0256GPM028-I/ML Microchip | от 60 ₽ | ||
PIC32MM0256GPM028-I/ML Microchip | 147 ₽ | ||
PIC32MM0256GPM028-I/ML Microchip | 462 ₽ |
Корпус | QFN |
Количество выводов | 28 |
# of Comparators | 3 |
ADCC with Computation | No |
Angular Timer | No |
Архитектура | 32 |
CPU | 32-bit MIPS MCU |
CRC/Scan | Yes |
Configurable Logic Cell Modules | 4 CLC |
EEPROM / HEF | 0 / HEF |
High Voltage Capable | No |
I2C | 3 |
Math Accelerator | No |
Max # PWM outputs | 18 including complementary outputs |
Max 16 Bit Digital Timers | 21 |
Max D/A Resolution | 5 bits |
Max. CPU Speed MHz | 25 |
Number of USB Modules | 1 |
Operation Voltage Min.(V) | 2 |
Pin count | 28 |
Размер памяти программ | 256 Kbytes |
RAM | 32768 bytes |
SPIв„ў | 3 |
Temp. Range Max. | 85 |
Temp. Range Min. | -40 |
Total # of A/D channels | 12 |
UART | 3 |
Zero Cross detect | No |
PIC32MM0064GPM028 PIC32MM0064GPM036 PIC32MM0064GPM048 PIC32MM0064GPM064 PIC32MM0128GPM028 PIC32MM0128GPM036 PIC32MM0128GPM048 PIC32MM0128GPM064 PIC32MM0256GPM036 PIC32MM0256GPM048 PIC32MM0256GPM064
Серия: PIC32MM0256GPM028 (4)
- PIC32MM0256GPM028-I/ML PIC32MM0256GPM028-I/SS PIC32MM0256GPM028T-I/ML PIC32MM0256GPM028T-I/SS
PIC32MM0256GPM028I/ML, PIC32MM0256GPM028 I/ML
