Линейка продуктов KEEN SIDE
Datasheet Microchip PIC32MM0256GPM028T-I/ML — Даташит
СерияPIC32MM0256GPM028
МодельPIC32MM0256GPM028T-I/ML
Краткое содержание:
PIC32MM0256GPM064 Family Data Sheet
PDF, 4.3 Мб, Версия: 05-25-2017
19 предложений от 9 поставщиков
64 ₽
727GS
от 131 ₽
от 137 ₽
от 403 ₽
КорпусQFN
Количество выводов28
# of Comparators3
ADCC with ComputationNo
Angular TimerNo
Архитектура32
CPU32-bit MIPS MCU
CRC/ScanYes
Configurable Logic Cell Modules4 CLC
EEPROM / HEF0 / HEF
High Voltage CapableNo
I2C3
Math AcceleratorNo
Max # PWM outputs18 including complementary outputs
Max 16 Bit Digital Timers21
Max A/D Resolution12 bits
Max D/A Resolution5 bits
Max PWM Resolution16 bits
Max. CPU Speed MHz25
Number of D/A Converters1
Number of USB Modules1
Operation Voltage Max.(V)3.6
Operation Voltage Min.(V)2
Peripheral Pin SelectYes PPS
Pin count28
Размер памяти программ256 Kbytes
RAM32768 bytes
SPIв„ў3
Temp. Range Max.85
Temp. Range Min.-40
Total # of A/D channels12
UART3
Zero Cross detectNo
PIC32MM0064GPM028 PIC32MM0064GPM036 PIC32MM0064GPM048 PIC32MM0064GPM064 PIC32MM0128GPM028 PIC32MM0128GPM036 PIC32MM0128GPM048 PIC32MM0128GPM064 PIC32MM0256GPM036 PIC32MM0256GPM048 PIC32MM0256GPM064
PIC32MM0256GPM028TI/ML, PIC32MM0256GPM028T I/ML
На английском языке: Datasheet Microchip PIC32MM0256GPM028T-I/ML
