Datasheet Microchip ATSAMC21J18A-ANT — Даташит
| Производитель | Microchip |
| Серия | ATSAMC21J18A |
| Модель | ATSAMC21J18A-ANT |
Серия устройств Microchip SAM C с напряжением 5 В Cortex M0+ предназначена для промышленного и коммерческого применения в шумных условиях.
Купить ATSAMC21J18A-ANT на РадиоЛоцман.Цены — от 12 до 729 ₽28 предложений от 17 поставщиков IC MCU 32BIT 256KB FLASH 56WLCSP. ARM® Cortex®-M0+ SAM C21 Microcontroller IC 32-Bit 48MHz 256KB (256K x 8) FLASH 56-WLCSP (3.4x3.2).... | |||
| ATSAMC21J18A-UUT Microchip | 12 ₽ | ||
| ATSAMC21J18A-MUT Microchip | от 105 ₽ | ||
| ATSAMC21J18A-UUT Microchip | 224 ₽ | ||
| ATSAMC21J18A-MUT Microchip | от 723 ₽ | ||
| Корпус | TQFP |
| Количество выводов | 64 |
| # of Comparators | 4 |
| ADCC with Computation | No |
| Angular Timer | No |
| Архитектура | 32 |
| CPU | Cortex-M0+ |
| CRC/Scan | Yes |
| Configurable Logic Cell Modules | 4 CLC |
| EEPROM / HEF | 0 / HEF |
| Hardware Touch Peripheral | PTC |
| High Voltage Capable | No |
| I2C | 6 |
| Internal Oscillator | 32khz, 32Khz ULP, 48Mhz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | Yes |
| Max # PWM outputs | 24 including complementary outputs |
| Max 16 Bit Digital Timers | 5 |
| Max 8 Bit Digital Timers | 5 |
| Max A/D Resolution | 12 bits |
| Max D/A Resolution | 10 bits |
| Max PWM Resolution | 32 bits |
| Max. CPU Speed MHz | 48 |
| Рабочий диапазон температур | от -40 до +105 °C |
| Operation Voltage Max.(V) | 5.5 |
| Operation Voltage Min.(V) | 2.7 |
| Peripheral Pin Select | Yes PPS |
| Pin count | 64 |
| Размер памяти программ | 256 Kbytes |
| RAM | 32768 bytes |
| SPIв„ў | 6 |
| Signal Measurement Timer | 1 |
| Temp. Range Max. | 85 |
| Temp. Range Min. | -40 |
| Total # of A/D channels | 12 |
| UART | 6 |
| Windowed Watchdog Timer | No WWDT |
| Zero Cross detect | No |
ATSAMC20E15A ATSAMC20E16A ATSAMC20E17A ATSAMC20E18A ATSAMC20G15A ATSAMC20G16A ATSAMC20G17A ATSAMC20G18A ATSAMC20J15A ATSAMC20J16A ATSAMC20J17A ATSAMC20J18A ATSAMC20N17A ATSAMC20N18A ATSAMC21E17A ATSAMC21E18A ATSAMC21G17A ATSAMC21G18A ATSAMC21J17A ATSAMC21N17A ATSAMC21N18A
Серия: ATSAMC21J18A (4)
- ATSAMC21J18A-ANT ATSAMC21J18A-AUT ATSAMC21J18A-MNT ATSAMC21J18A-MUT
ATSAMC21J18AANT, ATSAMC21J18A ANT
