Оптопары и оптореле Megawin
Datasheet Linear Technology LT4180EGN#TRPBF — Даташит
СерияLT4180
МодельLT4180EGN#TRPBF
Виртуальный контроллер дистанционного управления
LT4180 - Virtual Remote Sense Controller
PDF, 358 Кб, Версия: B, Файл закачен: 12 ноя 2017
, Controller 3.1V to 50V 24-Pin SSOP N T/R
LT4180EGN#TRPBF
132 ₽
LT4180EGN#TRPBF
304 ₽
727GS
LT4180EGN#TRPBF
от 2 119 ₽
TradeElectronics
LT4180EGN-TRPBF
КорпусSSOP-24
Код корпусаGN
Индекс корпуса05-08-1641 (GN24)
Demo BoardsDC1504A
Design ToolsLTspice File
Экспортный контрольнет
Основные особенностиVirtual Remote Sense
Isupply1 мА
Number of Supplies1
Рабочий диапазон температурот 0 до 85 °C
Vin Max50 В
Vin Min3.1 В
  • 2-Wire Virtual Remote Sensing for Voltage Regulators - Clairvoyance Marries Remote Sensing &mdash AN126
    PDF, 1.4 Мб, Файл опубликован: 1 окт 2010
    Wires and connectors have resistance. This simple, unavoidable truth dictates that a power source’s remote load voltage will be less than the source’s output voltage. Traditional methods for countering this include increasing the power source voltage and "4-wire" remote voltage sensing. Both have limitations. A new IC based approach achieves "virtual" remote sensing at the load without adding the usual two extra sense wires. Numerous circuit examples show the IC working with various voltage regulators and remote loads. Appendices detail IC internal operation and design guidelines for applying the part in any regulator circuit.
Design Notes
  • Tighten Supply Regulation for 2A USB Devices by Dynamically Compensating for Voltage Drops in Wiring and Connectors &mdash DN1029
    PDF, 121 Кб, Файл опубликован: 27 фев 2013
Статьи
  • Virtual Remote Sensing Improves Load Regulation by Compensating for Wiring Drops Without Remote Sense Lines &mdash LT Journal
    PDF, 1.8 Мб, Файл опубликован: 30 июн 2010
  • Monitor, Control and Protection > Cable Drop Compensation
  • Space & Harsh Environment > Extended Temperature Plastic (H & MP) > Extended Temperature (H & MP) Power Management
LT4180EGNTRPBF, LT4180EGN TRPBF
На английском языке: Datasheet Linear Technology LT4180EGN#TRPBF
