Datasheet MAX3232EEWE+ - Maxim Даташит TRANSCEIVER ИС ((NS)) — Даташит
Наименование модели: MAX3232EEWE+
![]() 54 предложений от 25 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
MAX3232EEWE Maxim | 65 ₽ | ||
MAX3232EEWE+T Maxim | от 146 ₽ | ||
MAX3232EEWE+ | по запросу | ||
MAX3232EEWE+ Maxim | по запросу |
Производитель: Maxim
Описание: TRANSCEIVER ИС ((NS))
19-1298; Rev 12; 12/10
±15kV ESD-Protected, Down to 10nA, 3.0V to 5.5V, Up to 1Mbps, True RS-232 Transceivers
General Description
The MAX3222E/MAX3232E/MAX3237E/MAX3241E/ MAX3246E +3.0V-powered EIA/TIA-232 and V.28/V.24 communications interface devices feature low power consumption, high data-rate capabilities, and enhanced electrostatic-discharge (ESD) protection.
The enhanced ESD structure protects all transmitter outputs and receiver inputs to ±15kV using IEC 1000-4-2 Air-Gap Discharge, ±8kV using IEC 1000-4-2 Contact Discharge (±9kV for MAX3246E), and ±15kV using the Human Body Model. The logic and receiver I/O pins of the MAX3237E are protected to the above standards, while the transmitter output pins are protected to ±15kV using the Human Body Model. A proprietary low-dropout transmitter output stage delivers true RS-232 performance from a +3.0V to +5.5V power supply, using an internal dual charge pump. The charge pump requires only four small 0.1µF capacitors for operation from
