Datasheet Linear Technology LTC2851 — Даташит
СерияLTC2851
Приемопередатчик RS485/RS422 3,3 В, 20 Мбит/с
LTC2850/LTC2851/LTC2852 - 3.3V 20Mbps RS485/RS422 Transceivers
PDF, 282 Кб, Версия: E, Файл закачен: 12 ноя 2017
LTC2851CDD#PBFLTC2851CDD#TRPBFLTC2851CMS8#PBFLTC2851CMS8#TRPBFLTC2851CS8#PBFLTC2851CS8#TRPBFLTC2851HDD#PBFLTC2851HDD#TRPBFLTC2851HMS8#PBFLTC2851HMS8#TRPBFLTC2851HS8#PBFLTC2851HS8#TRPBFLTC2851IDD#PBFLTC2851IDD#TRPBFLTC2851IMS8#PBFLTC2851IMS8#TRPBFLTC2851IS8#PBFLTC2851IS8#TRPBFLTC2851MPDDLTC2851MPDD#PBFLTC2851MPDD#TRPBFLTC2851MPMS8LTC2851MPMS8#PBFLTC2851MPMS8#TRPBFLTC2851MPS8LTC2851MPS8#PBFLTC2851MPS8#TRPBF
N123456789101112131415161718192021222324252627
Корпус3x3 DFN-8
Габаритный чертеж корпуса
3x3 DFN-8
MS-8
MS-8
SO-8
SO-8
3x3 DFN-8
3x3 DFN-8
MS-8
MS-8
SO-8
SO-8
3x3 DFN-8
3x3 DFN-8
MS-8
MS-8
SO-8
SO-8
3x3 DFN-8
3x3 DFN-8
3x3 DFN-8
MS-8
MS-8
MS-8
SO-8
SO-8
SO-8
Код корпусаDDDDMS8MS8S8S8DDDDMS8MS8S8S8DDDDMS8MS8S8S8DDDDDDMS8MS8MS8S8S8S8
Индекс корпуса05-08-169805-08-169805-08-166005-08-166005-08-1610 (S8)05-08-1610 (S8)05-08-169805-08-169805-08-166005-08-166005-08-1610 (S8)05-08-1610 (S8)05-08-169805-08-169805-08-166005-08-166005-08-1610 (S8)05-08-1610 (S8)05-08-169805-08-169805-08-169805-08-166005-08-166005-08-166005-08-1610 (S8)05-08-1610 (S8)05-08-1610 (S8)
Количество выводов888888888888888888888888888
Parameters / ModelsLTC2851CDD#PBFLTC2851CDD#TRPBFLTC2851CMS8#PBFLTC2851CMS8#TRPBFLTC2851CS8#PBFLTC2851CS8#TRPBFLTC2851HDD#PBFLTC2851HDD#TRPBFLTC2851HMS8#PBFLTC2851HMS8#TRPBFLTC2851HS8#PBFLTC2851HS8#TRPBFLTC2851IDD#PBFLTC2851IDD#TRPBFLTC2851IMS8#PBFLTC2851IMS8#TRPBFLTC2851IS8#PBFLTC2851IS8#TRPBFLTC2851MPDDLTC2851MPDD#PBFLTC2851MPDD#TRPBFLTC2851MPMS8LTC2851MPMS8#PBFLTC2851MPMS8#TRPBFLTC2851MPS8LTC2851MPS8#PBFLTC2851MPS8#TRPBF
ConfigurationFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-DuplexFull-Duplex
Drivers111111111111111111111111111
ESD, kV151515151515151515151515151515151515151515151515151515
Экспортный контрольнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнет
FailsafeIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, ShortIdle, Open, Short
Fault ProtectionVCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15VCC-15, +15
Isupply, мА0.450.450.450.450.450.450.450.450.450.450.450.450.450.450.450.450.450.450.450.450.450.450.450.450.450.450.45
Max Data Rate, Mbps202020202020202020202020202020202020202020202020202020
Рабочий диапазон температур, °Cот 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от 0 до 70от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 125от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -40 до 85от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125от -55 до 125
Protocols SupportedTIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422TIA/EIA-485, -422
Receivers111111111111111111111111111
Shutdownнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнетнет
Диапазон напряжения питания3.33.33.33.33.33.33.33.33.33.33.33.33.33.33.33.33.33.33.33.33.33.33.33.33.33.33.3
RoHSСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимСовместимНе совместимСовместимСовместимНе совместимСовместимСовместимНе совместимСовместимСовместим
LTC2850 LTC2852
  • Interface > RS485/RS422 Transceivers | Extended Temperature (H & MP) Interface
На английском языке: Datasheet Linear Technology LTC2851
Политика конфиденциальности
