Datasheet Linear Technology LTM2881HY-3#PBF — Даташит
СерияLTM2881-3
МодельLTM2881HY-3#PBF
Полностью изолированный микромодуль RS485/RS422 + питание
Datasheet LTM2881
PDF, 594 Кб, Язык: анг., Файл закачен: 12 ноя 2017, Страниц: 24
Complete Isolated RS485/RS422 μModule Transceiver + Power
24 предложений от 14 поставщиков
DGTL ISO 2.5KV RS422/RS485 32BGA. RS422, RS485 Digital Isolator 2500Vrms 2 Channel 20Mbps 30kV/µs CMTI 32-BBGA. Digital Isolators
LTM2881HY-3#PBF
1 883 ₽
Hi-Tech Circuit Group
LTM2881HY-3#PBF
LTM2881HY-3
727GS
LTM2881HY-3#PBF
Корпус15mm x 11.25mm x 3.42mm BGA
Код корпусаBGA
Индекс корпуса05-08-1851
Demo BoardsDC1503A-A,DC1503A-B,DC1746A-A,DC1746A-B
Drivers1
Экспортный контрольнет
Основные особенностиAdjustable Slew Rate, Isolated
Isolation Rating2500 Vrms
Max Data Rate20 Mbps
Рабочий диапазон температурот -40 до 125 °C
Protocols SupportedRS485, RS422, PROFIBUS
Receivers1
Диапазон напряжения питания3V to 3.6V
TerminationIncluded
LTM2881 LTM2881-5
  • Using the LTM2881 as an Isolated 5V Power Supply &mdash AN125
    PDF, 95 Кб, Файл опубликован: 5 фев 2010
    The LTM2881 is an isolated RS485 transceiver that guards against large ground-to-ground differentials. An onboard DC/DC converter provides isolated 5V power to the output. This application note shows the LTM2881 configured as a dedicated isolated power supply with the RS485 transceiver disabled, providing a simple powerful general purpose isolated power supply capable of delivering 1W at 5V.
Статьи
  • Isolated Data Transmission and Power Conversion Integrated Into a Surface Mount Package &mdash LT Journal
    PDF, 1.4 Мб, Файл опубликован: 18 янв 2011
  • Interface > Isolated Transceivers > µModule Isolated Transceivers
  • Interface > RS485/RS422 Transceivers | Extended Temperature (H & MP) Interface
LTM2881HY-3PBF, LTM2881HY-3 PBF, LTM2881HY3#PBF, LTM2881HY 3#PBF
На английском языке: Datasheet Linear Technology LTM2881HY-3#PBF
