Datasheet Texas Instruments CC1131QRHBRG4Q1 — Даташит
СерияCC1131-Q1
МодельCC1131QRHBRG4Q1
Недорогой радиочастотный приемник малой мощности с частотой менее 1 ГГц 32-VQFN
Low-Power Sub-1-GHz Fractional-N UHF Device Family for Automotive datasheet
PDF, 1.6 Мб, Версия: B, Файл опубликован: 16 апр 2010
RF RX FSK/GFSK 310-348MHZ 32VQFN. Automotive, AEC-Q100 RF Receiver FSK, GFSK, MSK, ASK, OOK 310MHz ~ 348MHz, 387MHz ~ 464MHz, 779MHz...
CC1131QRHBRG4Q1
65 ₽
CC1131QRHBRG4Q1
2 515 ₽
CC1131QRHBRG4Q1
CC1131QRHBRG4Q1
Pin3232
Package TypeRHBRHB
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаQQ1CC1131
Width (мм)55
Length (мм)55
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
Data Rate(Max)250 kbps
Device TypeUHF Receiver
Frequency Bands315,433,779,868,915,920 МГц
RX Current (Lowest)15.5 мА
RatingAutomotive
Sensitivity (Best)-114 dBm
Special FeaturesAEC-Q100 Grade 1/125В°C
TechnologySub-1 GHz
Throughput(Max)0.6 Mbps
  • DN013 -- Programming output powers on CC1101 (Rev. A)
    PDF, 238 Кб, Версия: A, Файл опубликован: 2 янв 2008
  • DN010 -- Close-in Reception with CC1101 (Rev. B)
    PDF, 102 Кб, Версия: B, Файл опубликован: 21 июл 2009
  • Resonant Trimming Sequence
    PDF, 88 Кб, Файл опубликован: 9 янв 2013
    This application report presents an efficient and precise method on how to achieve the desired resonant frequency of configuring the trim array with only a few iterations and measuring the resonant frequency. First, the minimum and maximum resonant frequency is measured; from this data a capacitance gradient is derived, which allows a good prediction of the required capacitance. The calculated cap
  • DN017 -- CC11xx 868/915 MHz RF Matching (Rev. A)
    PDF, 328 Кб, Версия: A, Файл опубликован: 31 мар 2008
    There are three versions of the CC11xx reference design which have been published. This design note gives a short introduction to RF matching and important aspects when designing products using the CC11xx parts and discusses the differences between the three reference design revisions.
  • DN500 -- Packet Transmission Basics (Rev. C)
    PDF, 174 Кб, Версия: C, Файл опубликован: 6 апр 2009
  • DN503 -- SPI Access (Rev. B)
    PDF, 94 Кб, Версия: B, Файл опубликован: 22 окт 2007
    The purpose of this design note is to show how the serial peripheral interface (SPI) must be configured to be able to communicate with the CC1100/CC1101/CC1150/CC2500/CC2550. It also shows how the status bytes should be interpreted and how SW reset is done over the SPI interface.
  • DN501 -- PATABLE Access (Rev. B)
    PDF, 66 Кб, Версия: B, Файл опубликован: 24 мар 2009
  • DN111 - Current Consumption for a Polling Receiver (Rev. A)
    PDF, 687 Кб, Версия: A, Файл опубликован: 24 мар 2009
  • DN505 -- RSSI interpretation and timing (Rev. D)
    PDF, 129 Кб, Версия: D, Файл опубликован: 16 июн 2010
  • AN072 -- Using the TAI-SAW TA0801A SAW Filter and External PA (Rev. A)
    PDF, 359 Кб, Версия: A, Файл опубликован: 19 авг 2009
  • AN050 -- Using the CC1101 in the European 868MHz SRD band (Rev. B)
    PDF, 223 Кб, Версия: B, Файл опубликован: 11 сен 2009
  • DN506 -- GDO Pin Usage (Rev. A)
    PDF, 219 Кб, Версия: A, Файл опубликован: 22 окт 2007
    The purpose of this design note is to explain how to use the different general digital output (GDO) pins for control and monitoring purposes. The focus is set on interfacing with a microcontroller unit (MCU) and is related to the CC1100, CC1101, CC1150, CC2500 and CC2550 devices.
  • DN022 -- CC110x CC111x OOK ASK Register Settings (Rev. E)
    PDF, 532 Кб, Версия: E, Файл опубликован: 8 мар 2012
  • DN005 -- CC11xx Sensitivity versus Frequency Offset and Crystal Accuracy (Rev. C)
    PDF, 96 Кб, Версия: C, Файл опубликован: 20 авг 2009
  • DN504 -- FEC Implementation (Rev. A)
    PDF, 110 Кб, Версия: A, Файл опубликован: 22 окт 2007
    This design note explains the functionality of forward error correction (FEC) and how it is used in the CC1100, CC1101, CC1110, CC1111, CC1150, CC2500, CC2510, CC2511, and CC2550 devices. Example code for FEC implementation is included.
  • DN016 -- Compact Antenna Solution for 868/915 MHz (Rev. B)
    PDF, 832 Кб, Версия: B, Файл опубликован: 20 авг 2009
  • DN024 -- 868 MHz, 915 MHz and 955 MHz Monopole PCB Antenna (Rev. E)
    PDF, 1.0 Мб, Версия: E, Файл опубликован: 22 фев 2013
  • DN502 -- CRC Implementation (Rev. D)
    PDF, 55 Кб, Версия: D, Файл опубликован: 27 окт 2009
  • DN033 - Mitsubishi Ceramic Antenna for 868 MHz, 915 MHz & 955 (Rev. A)
    PDF, 685 Кб, Версия: A, Файл опубликован: 14 сен 2010
  • DN023 -- 868 MHz, 915 MHz and 955 MHz Inverted F Antenna (Rev. C)
    PDF, 369 Кб, Версия: C, Файл опубликован: 30 авг 2011
Серия: CC1131-Q1 (3)
  • Semiconductors > Wireless Connectivity > Companion Wireless Solutions > Smart RF Transceivers
На английском языке: Datasheet Texas Instruments CC1131QRHBRG4Q1
